Is this really a 1966?
Old Sep 5, 2013 | 10:56 PM
66f-100's Avatar
66f-100
Antique wrecker project, 1966 Ford F350, Holmes 1200
Old Sep 5, 2013 | 11:53 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
I am not much on the slicks, but it does look like my 66 from the details I could see.
Old Sep 6, 2013 | 12:31 AM
Scifi266's Avatar
Scifi266
In my opinion hell no, but I'm not really sure the differences in cabs above the 250 rating. It looks like the front is 66 but the cab looks like a 64 since it has the step and the steering column and he says the battery is in the passenger floor. I thought that only 4x4 65-66 had the older style cabs.
Last edited by Scifi266; Sep 8, 2013 at 02:43 PM. Reason: Cause na, I was tired at the time and didn't catch my typing.
Old Sep 6, 2013 | 01:09 AM
Ziegelsteinfaust
Your right I did not catch the column.
That has to be a 64 and earlier cab atleast.
Old Sep 6, 2013 | 01:36 AM
jmd13818's Avatar
jmd13818
Grille is a 66 for sure, but I agree dash and cab resembles a 64.
Old Sep 6, 2013 | 04:22 AM
wtx66f100's Avatar
wtx66f100
If I remember right the one ton's still had the step and were not the same as the half ton.
wtx66f100
Old Sep 6, 2013 | 07:14 AM
rogue40's Avatar
rogue40
It is a 66.
Old Sep 6, 2013 | 05:32 PM
Buzz44's Avatar
Buzz44
It looks like it has the taller roofline in the pics. That would make it a 64-66 one ton.
Old Sep 6, 2013 | 08:37 PM
rogue40's Avatar
rogue40
Same cab as 66 F250 4x4.
Old Sep 7, 2013 | 12:56 PM
Buzz44's Avatar
Buzz44
The heater box would be a determining factor and I cant get a real good look at it in the pix. It does look to be a 65-66 heater box but I cant see it very well.
Old Sep 7, 2013 | 04:00 PM
The Masked Rider's Avatar
The Masked Rider
Note the larger front fender wheel opening - larger series trucks. I also think the 65 and 66 of some of the 250 and 350 used the early cabs with the 'step in' area. I could be completely wrong But I'll bet ND will know.
Old Sep 7, 2013 | 06:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
^ Of course I know, and so should everyone else typing in this thread, as I've listed this same info over 100 times.
Originally Posted by Scifi266
In my opinion hell no.
6 lug wheels on a 7.25" bolt circle: 1953/66 F350 & P350 (P Series Parcel Delivery) only.
Cab step, visible when doors are opened: 1961/64 F100/1100 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD
No cab step: 1965/66 F100/250 2WD & 1966 F100 4WD
Same steering column: 1961/65 F100/250 4WD / 1961/66 F350/750 / 1966 F250 4WD
45" radius front fenders: C2TZ-16005-D Right & C2TZ-16006-D Left. Here are the applications for 1964/66 F350 and etc.
Old Sep 7, 2013 | 06:58 PM
arctic y block's Avatar
arctic y block
Yep. It's the same 66 F350 I have in my yard. Wish that one was here also.
Would put my engine in and have a blast.
Old Sep 7, 2013 | 10:03 PM
rogue40's Avatar
rogue40
I tried...
Old Sep 8, 2013 | 10:07 AM
tripleframe's Avatar
tripleframe
Looks like a solid truck, yes a '66. I like the term "commercial style cab", referring to the high step cab which was actually used up to 1969 (with an even higher roofline) on some of the heavier series trucks. The worst thing about it appears to be the cheapo repaint.
