No Start,no power, no lights,no nothing
Originally posted by rivan
I do not know if this switch "when tripped" will kill "all" electrical power. It would seem so because if the vehicle were in a wreck & gas 'all over the place' you would not want any electrical power to go to the starter or any where, Right. I hope this helps.
Rick
Could it be a faulty Solenoid? My truck wouldn't start or turn over two months ago, nor would any of the lights go on, just after just having had the starter and positive cable replaced. Someone with mechanical training came along, jiggled a few wires and told me it was the solenoid. Sure enough, after buying and replacing it, the truck started again.
Charlotte
Charlotte
I feel Soooo stupied!
After trying everthing I could think of and following the advise that I found on this forum and nothing worked I had it towed for repair.
Couple of hours later was called and told my "5 month old Battery was bad" New battery and it starts and runs fine. The battery was showing almost 13 on the volts meter. I even took the battery out of my old 84' ranger and tried to start my 89' got nothing. But the 84'ranger would start every time. And it's battery is 5 years old.
I'm still puzzled as to why this happend. I nomally replace my battery after it's 4 to 6 years old anyway. That's the only reason I bought a new one for my 89 ranger. The old battery in the 89 was starting the truck fine, I replaced it only because of it's age.
Now my "Check engine " light flashes On every now and then.
Must be time for a tune up.
Steven,
I had the same symtoms you did. Would lose all power when I would try to start my truck. I changed the starter solinoid but the problem came back after a few days. I was considering an ignition switch problem until I read your post and noticed no one mentioned an ignition switch as a possible solution. I took their advice and started at the source. The battery. In your case you changed yours. In my case I cleaned my terminals. Made up a strong solution of baking powder and water. Removed the terminal bolts and soaked all in the solution until no more bubbles. Cleaned the battery top off and the posts. Put it back together and no more problem. Starts every time. I suspect you probably had a corrosion problem too. Your strong battery could get through it but you weak one couldn't. If the problem shows back up I guess it's time for me to buy a new battery.
No start no power no light nothing
SteveRanger
First of all I apologize for any inconvenience reaching out have a 1987 Ford Ranger 2.3L similar problem as your vehicle if you don’t mind asking what was the outcome?
I try everything has new battery, solenoid, ignition switch, ground are good, and all fuses are good.
Regards
Rene
Regards
Rene
atxF100
19
05-12-2012 10:37 PM
leeg777
1997-2006 Expedition & Navigator
09-05-2011 12:11 PM
AWick20
03-21-2010 04:48 PM
