rear axle replacement
Old Sep 4, 2013 | 04:54 PM
timmyboy76's Avatar
timmyboy76
....well, i shot from the hip again. Got my new/used axle from a 04 f350 SRW, and unfortunetly it came with a "disk" yoke to driveshaft connection. Not knowing, i spun the nut off to remove yoke and did so with my used one, to swap them. Here's the fun, not knowing about proper preload..etc, i just impacted the damn thing on.
Its not leaking ,but i know its not "set" correctly. Should i chance driving it to get it fixed correctly or have it trailered to shop?
Old Sep 4, 2013 | 05:20 PM
429 f-100's Avatar
429 f-100
timmy, I thought the same when my pinion seal was leaking being the **** person I am about procedure ect I took it to my buddy who runs a mechanical shop ( assuming that he would check preload, backlash ect ) he just took off and impacted it back on . now he is a very good tech and he told me it would be fine been three years now no problems . I say drive it just keep a eye on it make sure it doesn't loosen up. backlash that is.
Old Sep 4, 2013 | 05:29 PM
timmyboy76's Avatar
timmyboy76
thanks man...problen is, when i go to turn the yoke, it seems to be binding. Not the case when i bought it. . I just removed the yoke again, and seems to be "free". I'm not seeing this "crush sleeve" that keeps being mentioned. Also, tore the seal out, so theres another 20 buks .
Old Sep 4, 2013 | 10:25 PM
mueckster's Avatar
mueckster
You may want to check if the seals are different. I ran into this on an '02 F350 with the Dana 80. He was given the wrong seal for the round disc flange model. There was a difference in the rock shield and the seal bound against the yoke when tightened. You may have to get a seal for your year model to match your yoke.
Old Sep 5, 2013 | 08:50 AM
tommyl's Avatar
tommyl
What did you pay for your used axle? I'm on the fence looking to do the same thing..
Old Sep 5, 2013 | 12:33 PM
timmyboy76's Avatar
timmyboy76
$300.00....Roland, i'm thinking that "rock-shield" are different for yoke application. Just looked at the yoke that came with axle that i installed on my original, and its bound up. The yoke w/shield from original axle thats on the new axle, is "sloppy" to say the least. Wondering if the "width" is playin a role here....gonna swap them, AGAIN, and hope for the best....
Old Sep 6, 2013 | 11:46 PM
timmyboy76's Avatar
timmyboy76
Guys, thought this was a great read, and is EXACTLY my situation...
Sterling 10.5" differences - PowerStrokeNation : Ford Powerstroke Diesel Forum
Which then, i need this...
http://www.justdifferentials.com/Pro...ode=SKCSF9-STD
rnelson664
Apr 29, 2016 09:09 PM
1stSD350
Oct 22, 2013 04:48 PM
miottimouse
Aug 21, 2013 11:08 PM
wreckinball
May 13, 2011 10:13 PM
SpectreZ91
Nov 12, 2007 07:16 PM
