power steering pump question
Old Sep 4, 2013 | 02:06 PM
Furniture Doctor's Avatar
Furniture Doctor
I have a996 F250 with a PSD. Are the power steering pumps interchangeable with other Ford cars and trucks? Mine is making noises and sometimes feels like I do not have power steering. Suggestions please.
Old Sep 4, 2013 | 02:48 PM
ReBilld's Avatar
ReBilld
I know the pumps on a 460 gas truck are the same as ours.
Old Sep 4, 2013 | 09:12 PM
mjunk1's Avatar
mjunk1
I can't imagine you can do much better than to buy a reman one. I paid $55 for mine at NAPA and it came with a reservoir, but alone it was even cheaper. Seem to me a junk yard is going to want $25 at least and then it might not work. There is a difference in part numbers for the one with hydroboost, but I think it is just having 2 return lines. The job is pretty simple. I had the same issue with mine and changed pumps this weekend and it is so much better to drive. If you search on here, though, you will see that for a number of people the issue was not the pump but the high pressure line. So take a little time to be sure it isn't leaking first. If you do change the pump, I recommend unbolting the A/C compressor from the bracket and then pulling the whole bracket off (4 bolts and it is free). Makes getting to the pulley much easier. Good luck.
Reefmonster
Jan 10, 2010 01:47 PM
monckywrench
Offroad & 4x4
May 12, 2009 07:39 PM
Trail_Rider
Apr 23, 2000 09:48 PM
400HP794x4
Apr 23, 2000 09:41 PM
