Bronco II Ford Bronco II
Replacing Suspension, so many options...
Old Sep 4, 2013 | 11:47 AM
Josh S's Avatar
Josh S
I've been going back and forth for some time about what to do about my suspension and want to get some other opinions. Maybe just typing this will help me make up my mind.
At a minimum I'd like to replace the stock coil & leaf springs this winter. The truck will continue to be my summer transportation for the next 4 years so street handling is most important right now. I like the 30"x9.5" tires on the truck but they're a little tight so I'm considering also adding 1.5" spacers/lift blocks. After about 4 years it will become a weekend truck that I'd like to use occasionally in Silver Lake Sand Dunes. Nothing crazy just something to take the family in. At that point I'll probably want a 4" lift with 31"x10.5" tires. I'd just go ahead with the 4" lift now but am afraid it will hurt street handling. I also pull a light duty trailer occasionally so stiffer rear suspension might not be a bad thing. For now I could probably do explorer leafs with new coils and 1.5" spacers for under $200 then plan to add a real lift in 4 years. I don't know, what do you guys think?
Old Sep 18, 2013 | 07:40 AM
Josh S's Avatar
Josh S
I found a set of used '94 Explorer leaf springs and believe they are the 4-leaf type. Just want to check in here first before buying to make sure they're the ones that I can flip the guide bolt and install on my '88 B2. The junkyard wants $100 (they remove) which doesn't sound too bad? I'm hoping they'll raise the ride about 1-1/2 - 2" and firm the suspension up a little for light towing.
As an update to my post above I plan to add explorer leafs, new stock coils, coil spacers, and bushings throughout. Then a few years down the road maybe a body lift. I'm just hoping to get better street handling now with the option for 31" tires later on.
Old Sep 19, 2013 | 07:44 AM
Josh S's Avatar
Josh S
Man I wish there were more active members in this forum. Feel like I'm talking to myself here.
Old Oct 8, 2013 | 07:27 PM
mdr617's Avatar
mdr617
The street handling will be affected by any modifications to the suspension and/or using a body lift and/or changing the tire size. I was running a 2" body lift on my 88' BII with stock suspension and 31"x10.5" tires on the stock wheels. It was effected, as if I would accelerate hard while making a U-turn the front wheel would come off the ground about 24". Overall, I think that the body lift would be your best option for reliability and street use, not to mention the lower price. I would just pay someone to install it because it takes some time and can be stressful.
I actually have a brand new 4" rough country suspension kit with all new springs that I never used because my BII's engine failed.
I have to ask, 4 years...college?
Old Oct 9, 2013 | 08:06 AM
Josh S's Avatar
Josh S
Thanks for the reply and the confirmation about street handling. I've got the B2 bob pretty bad when shifting gears so something does need to be done about the current 25 year old suspension. I'll be more or less replacing stock components for now with the plan to do a little customizing later on. Still trying to get some time away from work to make it to the junkyard for explorer leafs.
I replaced the body bushings on my ranger a little while back but have not done a body lift. Is it significantly harder?
"I have to ask, 4 years...college?"
Actually finished my 8 years a few years ago. Really it's just been the plan for the Bronco II since I bought it, 5 years driving it in the summers then retire it for weekend use and buy a newer ranger as a dd to replace my current '94 that I drive in the winters. I put the Bronco II in storage a week ago and am missing it already. Will give me time to do the suspension work though. Too bad about your BII's engine.
Old Nov 16, 2013 | 04:47 PM
Josh S's Avatar
Josh S
I'm having trouble finding a 2" body lift kit that includes the brackets to raise the bumpers. I've checked Ebay, JBG, Rough Country, and Superlift.
Old Nov 16, 2013 | 05:55 PM
Old93junk's Avatar
Old93junk
Most people just leave the bumpers at stock height with such a modest lift.
Old Nov 17, 2013 | 04:21 PM
Josh S's Avatar
Josh S
That's probably why I can't find any kits with the bumper brackets. Maybe I'll go that route too then. It would allow me to keep using the bumper hitch a little longer for light towing.
The front 2 body mounts came off today. What a pain that was. The 26 year old bolts were rusted solid... but I won. Only 8 more to go.
Old Nov 18, 2013 | 11:22 AM
Josh S's Avatar
Josh S
Mdr617, Did I see in another post that you didn't need to extend the steering, brake lines, or anything else since you went with 2" lift rather than 3"? 2" would suit my needs better anyway but omitting all the other mods that go along with a body lift would be a big plus.
Old Jan 6, 2014 | 04:36 AM
mdr617's Avatar
mdr617
Exclamation
If you are still looking for lifts, I have a BRAND NEW Rough Country 4" suspension lift system/kit WITH NEW REAR LEAF SPRINGS instead of blocks, with new shackles, all ready to install. The only thing you would need to possibly add is a pitman arm.
I also have a NEW set of extended stainless steel brake hoses, which are listed for sale right now on E-Bay.
If interested, message me on E-Bay. My username is 1ford1988.
I also have a rare off-road Xlt package rear tubular NOS OEM bumper for sale as well. I posted in the classifieds on here as well, there are a LOT of parts I am going to be selling.
Old Jan 6, 2014 | 04:38 AM
mdr617's Avatar
mdr617
Yes, that is correct. I had ran a 2" set of coil spring spacers up front with a set of 2" lift blocks in the rear on a stock 88' Bronco II.
Brianm83
Sep 27, 2014 01:12 PM
chumlysgrl
1997 - 2003 F150
Jul 8, 2005 01:30 PM
Quackhead94ranger
Offroad & 4x4
44
May 29, 2005 03:32 PM
knucklehead11
Offroad & 4x4
Jun 30, 2003 12:09 PM
chieff
Jan 16, 2001 05:38 AM
