REALLY Hot Doghouse
Old Sep 3, 2013 | 03:51 PM
vrovl's Avatar
vrovl
REALLY Hot Doghouse
I've read all the posts about hot doghouses (that I have had an issue with on this E350 motor home from day 1) and I've read all the fixes BUT....
My problem went from overly warm to the doghouse surface temp so hot the plastic was pliable in just minutes. Like everyone, down by the gas pedal. There is no carpet on the doghouse. What was also disconceting was black smoke in the cab when the A/C was flipped on for a second or two.
Doghouse hits extreme temperature after only minutes idling. Motor runs normally. Normal has always been loud. Over 30 mph smoke is visable coming out from the undercarriage. All gauges normal, all fluids ok, oil clean, tranny fluid pink, rad full and lime green, no visible signs of heat damage viewed from underneath. No obvious holes in heat shield. Could there be one? Or do I have a problem (manifold?) I have not found in the forums?
Old Sep 3, 2013 | 05:22 PM
blageurt's Avatar
blageurt
What engine do you have ?
Old Sep 3, 2013 | 06:30 PM
vrovl's Avatar
vrovl
4.9L on E-350 basic striped chaisse with RV prep package under a C class RV
Old Sep 3, 2013 | 07:37 PM
Club Wagon's Avatar
Club Wagon
"Doghouse hits extreme temperature...smoke in the cab...always been loud" -smells like big exhaust leak; bad exhaust gasket, bad manifold, or bad head pipe?
Originally Posted by vrovl
doghouse surface temp so hot the plastic was pliable black
smoke in the cab
Old Sep 3, 2013 | 08:09 PM
Tom's Avatar
Tom
This. Sounds like you have exhaust blowing against the doghouse. This could be dangerous.
texinwa
6.2L V8
Feb 6, 2018 04:45 PM
copen93
Feb 11, 2015 03:37 AM
Harkeyms
6.4L Power Stroke Diesel
Mar 15, 2012 11:36 AM
66fordf100
Nov 26, 2007 05:45 PM
Beast12
Exhaust Systems
Apr 19, 2004 08:23 PM
