6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
White smoke
Old Mar 14, 2012 | 09:26 AM
Harkeyms's Avatar
Harkeyms
White smoke
I'm new to diseil trucks had mine 2008 6.4 f250 about 3months now and recently noticing white smoke not all the time but maybe 2 times a day and recently noticed a cleaning exhaust filter read out on panel I don't drive the truck more than 20 miles a day around town can anyone explain why I might be getting smoke from my truck thanks for any help
Old Mar 14, 2012 | 12:07 PM
senix's Avatar
senix
I could mean that you are in the exhaust cleaning cycle or regen of the DPF and due to low speeds and an exhaust that is not that hot you are blowing some smoke.
The regen process works best on the hwy. This motor will be much more effiecient as a hwy or towing motor.
It needs to get up to temps and stay there. 20 miles is actually about 10 miles each way which does not really get things warmed up enough to start the process let alone finish it.
Go take it on the hwy and let it get completed.
Old Mar 14, 2012 | 12:53 PM
Harkeyms's Avatar
Harkeyms
Thanks again senix you have been alot of help
Old Mar 14, 2012 | 02:41 PM
aquaman's Avatar
aquaman
The DPF/regens is the #1 source of all evil in our trucks!!
Regens finish best if you can keep a constant throttle like freeway or expressway driving so the exhaust can heat up and maintain consistent heat.
Stop and go traffic and regens do not mix. The engine will dump fuel out the exhaust in futile attempt to heat the exhaust. If the exhaust isn't hot enough, smoke blows out like pouring BBQ fluid on hot coals. I was behind a guy doing that just the other day, and it smells vicious. It cuts right into the lungs.
The smoking is a common complaint and has a fairly big discussion among other forums as well. I will belch smoke about a minute into regen immediately after taking off from a long light on cold days. Very predictable and it lasts about a minute each time or as soon as the exhaust /CAT heats up again.
Old Mar 14, 2012 | 03:19 PM
chi6488's Avatar
chi6488
there is something wrong with your truck. Good luck to you to get ford or a ford dealership tech to address your problem. They will tell you it is normal.
Your smoking might get worse and you will look like a locomotive train going down the road in a $50k truck and be embarrassed as hell.
The only solution I found was to delete.
The driving until exhaust clean until end didn't help me either. I would go out of my way and drive the 15-20 miles until it was clean but I still looked like a train going down the road. This was when I gave up and deleted.
Good luck
Old Mar 15, 2012 | 05:45 AM
chi6488's Avatar
chi6488
Once you delete you will be glad you did with the extra power and NO hassle with the clean exhaust crap.
I am only running a "mild" tune from H&S and happy as all get out with the truck now.
Old Mar 15, 2012 | 11:36 AM
aquaman's Avatar
aquaman
The issue of stuck EGR valves are more for the folks who need to return to stock and have to 'look back' every once in a while.
bsharp22
2015 - 2020 F150
May 25, 2019 11:25 AM
dynarider33
Aug 28, 2014 07:52 PM
DieselBeast01
Dec 25, 2008 08:02 PM
Yeti DHer
Oct 25, 2002 03:46 PM
BigPro
Exhaust Systems
Jan 12, 2002 12:46 AM
