Fuel problem
Old Sep 2, 2013 | 10:46 PM
tbm3fan's Avatar
tbm3fan
Fuel problem
Yes, have a fuel problem but it is not in the truck. It is in the car blocking the truck in the side driveway. A month ago the Parklane was running right up until it stopped dead. Thought it was ignition but when all checked out I got a little puzzled. After killing the battery twice I decided to move on.
Two weeks ago I'm back at the car and noticed that the rubber fuel line disconnected from the main line. In the car Ford ran a hard plastic line from the tank to the front with it ending just past the crown of the driver's side inner wheel housing. Of course it ended under the speed control box which is why I didn't see it right away.
Connected it and went to work. Still no fuel. Pulled line off the carb and put into container. Cranked engine over and got nothing!!! Ok, not my favorite task on this car but I replaced the fuel pump over the last two days. Just was out cranking the engine and still NO fuel from a tank with 16 gallons in it. Charging battery once again while I ponder what is my next move. Ideas?
Old Sep 2, 2013 | 11:55 PM
The Masked Rider's Avatar
The Masked Rider
Need more info. I'm sure the guys will also ask.
Make, model, year. ?
Reason for asking, there may be a fuel filter attached to the frame or next to gas tank. OR even 'in' the gas tank. You might check for a fuel filter and disconnect the line before it to see if gas will flow. Be careful though, you have a bunch of fuel in that tank and it could come pouring out. I had a problem like that some years ago and I disconnected the fuel line at the pump and hit it with some air going back toward the fuel tank. Solved the problem so we could get the car moving, BUT, it wasn't long before the problem returned. It ended up a plugged fuel filter that was mounted on the left side frame, just below the driver door.
Good luck...
NOTE: if you hit the fuel line with air,,, REMOVE the fuel 'fill' cap first or you will just pressurize the fuel tank and it will come blasting back out the line you are blowing air into.
Old Sep 3, 2013 | 01:46 AM
tbm3fan's Avatar
tbm3fan
In my sig 1967 Park Lane 410-4V.
MedicMoe
Oct 27, 2010 12:39 AM
LariatF350
Mar 3, 2010 02:17 PM
cadunkle
Oct 26, 2009 09:19 PM
AbandonedBronco
24
Oct 12, 2009 12:17 PM
wcsd106
Feb 9, 2008 01:13 PM
