AOD overdrive problems
Old Sep 1, 2013 | 09:00 PM
hambone3531's Avatar
hambone3531
I have a 93 f150 4x4 with the aod auto trans and recently the overdrive started sliping and not engageing at all at times till I stomp down on the go pedel and she hits about 4 grand but it will only hold for a few seconds then start sliping again I checked the fluid level its fine and its clean and smells ok 1st through 3rd still shift fine and the transfer case works fine too I added some transmission slippage and seal additive and some zmax additive but havent drivin much with it in so dont know if will do any good she is my only transportation I have so I dont wanna open her up and take a peak since she does still drive fine just dosent like to pass gas stations anymore without the od any ideas or info would be much appriciated
Old Sep 1, 2013 | 09:24 PM
Conanski's Avatar
Conanski
So you're positive you have the AOD and not the 4R70W or E4OD? What is the trans code on the drivers door pillar?
Old Sep 1, 2013 | 10:06 PM
hambone3531
No not real sure its got the 14 bolt pan and the trans code is a T on the door jam sticker
Old Sep 1, 2013 | 10:26 PM
dixie460's Avatar
dixie460
Trans code T and 14 bolt pan = AOD.
First thing is to check fluid level, you said it's fine but how exactly did you do this? The correct way is on a level surface, with transmission warm and engine idling. Shift into each position on the gearshift and let the trans actually complete the shift. Start from park, stop at each position, then work your way back to park again. Now you can pull the stick and check the level. The reason you have to hit all the gears first is to allow oil to fill the accumulators and clutch drums, etc.
Second thing... the kickdown cable on an AOD not only controls kickdown, but also controls line pressure. Meaning, if you don't have it adjusted right, you could burn up the transmission in just a few miles. There is a procedure for it, check the repair manual for your truck or try a search online. This cable is also known as a TV Cable (throttle valve cable).
Old Sep 1, 2013 | 10:42 PM
hambone3531
Well I checked it propper runnin through the gears and all that and Ive driven prolly a good 1200 miles since the sliping not engageing started and just come home from a weekend trip and racked up about 250 miles and picked up the additives on my way home and put them in before takin my girlfriend home and put about 40 more miles on her ive only been runnin it in drive cause im afraid if I keep tryin od it might just start getin worse and ill loose more gears the previous owner a ford mech had a jasper rebuilt put in about 70000 miles back so I figure it shoulda went a little longer then that but maybe its rebuild time I just cant afford it in both money and down time with it bein my only wheels
KaiserKlauss
May 13, 2016 10:42 AM
captain1997
1978 - 1996 Big Bronco
Aug 26, 2013 11:20 AM
4x4-jacked-up-93
Jan 14, 2011 12:19 PM
Supercab
Apr 25, 2009 07:16 PM
3broncocrazy
May 19, 2008 08:09 PM
