911 HELP- NO BOOST?!?!?
Old Sep 1, 2013 | 06:53 PM
mustang_309's Avatar
mustang_309
Perhaps the EGR valve is stuck open and that is where all the exhaust is going instead of the turbo.
Old Sep 1, 2013 | 06:56 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
When my EBP sensor went out, I could do maybe 10 mph wide open throttle while belching black smoke everywhere. I checked the parameters between the BARO, MAP and EBP and the EBP was way off compared to the other two. I didnt throw a CEL but I didnt scan for codes either. Was going off of symptoms.
Old Sep 1, 2013 | 07:09 PM
04badford's Avatar
04badford
Originally Posted by Pridnjoy
Ugh. Looks like its more than the turbo. Disconnected the boat and tried driving. Not enough power to go over 5 miles an hour and 100 yards. Pulled off, disconnected the battery and drained the rail mounted fuel separator. Tried again and same thing. Now it's parked. Guess a tow truck and trip to the dealer is next. As a side note, the fuel in the fuel tank has been in there for a week and 400 miles. So I do not think its bad fuel. Edge Insight showed several codes, all EGR related and one that said something about minimum turbo boost...
On your Other Thread the EGR was unplugged, did you unplug and see what happens .HMMM there must be a tunner on this truck? If the EGR is in by hooking it back up mite have open or closed it ,I would pull it and clean with carb cleaner, ware some glasses it will burn your eyes, M-chan, benny ?
Old Sep 1, 2013 | 07:11 PM
04badford's Avatar
04badford
Whats the other code that came up?
Old Sep 1, 2013 | 07:33 PM
big inch's Avatar
big inch
A stuck open egr valve will cause those symptoms. If the valve had been disconnected for a long time, and was recently plugged back in, there may have been a build up of carbon that got stuck in the valve.
The egr valve is pretty easy to remove with an 8mm socket, extension and ratchet and a large pair of channel lock pliers.
Old Sep 1, 2013 | 07:35 PM
m-chan68's Avatar
m-chan68
To you and I, it may be relatively easy to remove, but to someone inexperienced it can be a bit of a chore if it's really stuck in there.
Old Sep 1, 2013 | 07:44 PM
04badford's Avatar
04badford
two flat bars twist counter clock wise and pry up, some have ran wire thru the bolt holes ,
Old Sep 1, 2013 | 07:45 PM
BLADE35's Avatar
BLADE35
He had to of Blown something OUT
HOOKED Up BOAT Only 3 Miles and BOOM went to Hell Fast
Maybe the CAC "Cooler" Itself Blew
Old Sep 1, 2013 | 07:46 PM
BLADE35's Avatar
BLADE35
Especialy if your stuck without Tools
He didn't drive far would the EGR Valve start doing its thing before 185*f EOT?? Im Curious Mike
Old Sep 1, 2013 | 08:34 PM
big inch's Avatar
big inch
That's true. Some of them put up a pretty good fight, especially if they have never been out before.
mustang_309
I know I will catch some hell for this but the way I got my EGR valve out was with a pair of 16" channel locks, by grabbing the metal sides and pulling while twisting.
Old Sep 1, 2013 | 09:48 PM
Pridnjoy's Avatar
Pridnjoy
Ding, ding, ding!!!! Thanks for everyone's help. After reading the posts, I thought about it and agreed that the EGR valve may be the culprit. Back down to the parking lot I went with the tools and an attitude. Twenty minutes later and a clean EGR valve, I was on my way. Back home and it was operating as it should.
Thanks for everyone's insight.
Old Sep 1, 2013 | 10:23 PM
  #28
04badford's Avatar
04badford
That's great news ,when you get home clean up the IAT2 senser too that will be sooted up, also the MAP connection to Intake the threaded nipple and hole in the Intake will clog, this will get you going ,Great place and Info here . No Place to be but on FTE
Old Sep 1, 2013 | 10:29 PM
  #29
BLADE35's Avatar
BLADE35
Good Call
The Added Boost Must pushed it Open Further then Normal and Stick It open
Did He get a CEL in this??
Old Sep 1, 2013 | 11:30 PM
  #30
04badford's Avatar
04badford
Nice Call Mustang, I was typing while you were answering. lol
