electrical stuff
Old Aug 30, 2013 | 10:00 PM
EgoMan's Avatar
EgoMan
electrical stuff
So, its been a long time since i have been on here and a long time since i have done work on my ride. I was trying to remember what I had to do to upgrade my electrical system to support modern electrical equipment like power windows/door locks, a new stereo and electronic ignition. For some reason a few years back I collected a BG one wire alternator and remember wanting to upgrade my voltage regulator? It's all so foggy these days. Does this sound right or should I just put an all new painless system in? I would rather not spend the money on a painless system to be honest... I just cant remember what I could and couldnt run off the stock 68 F100 system. I know my stereo now takes quite a drain!
Old Aug 30, 2013 | 10:28 PM
HIO Silver's Avatar
HIO Silver
High ampin' sound system? You need to do the 130-amp, 3g alternator retrofit. It has been done for as little as $25. Super EZ.
Go to this post and go to the 3g section: https://www.ford-trucks.com/forums/1...l#post13139591
Old Aug 30, 2013 | 11:50 PM
Cracker289's Avatar
Cracker289
I have a later model high amp from a 90's Ford Taurus, and what I did was run a separate box full of relays, and then the power that feeds them goes through a circuit breaker, and then original wiring is used to turn the relays on and off, so I get full power to headlights, to ignition, electric fan, etc, but without having to alter any of the original wiring under the dash. I also ran a wire through a circuit breaker and routed it to the inside of the cab and used that power source for modern radio, and anything else I need inside the cab (second cigarette lighter outlet for phone charger or GPS, etc). So far its worked out well, it takes a lot of the amps away from the original wires because all they are doing now is turning the relays on and off.
Old Aug 31, 2013 | 08:16 AM
EgoMan's Avatar
EgoMan
I figured I would have to do the alternator. I thought there was a voltage regulator upgrade you could do also? Like one from a newer f150.... I don't know I might be thinking of something else.
I really like the relay box idea but I have no idea whats involved in that is it difficult to get the required parts? I don't know a lot about wiring that's why I ask.
Old Aug 31, 2013 | 09:02 AM
MavSprint's Avatar
MavSprint
I added an expansion fuse block to a '72 Maverick for extra circuits. Don't recall where I bought it but the expansion block had 4 switched (ignition on) circuits and 3 always-on circuits. A relay fed the switched circuits.
Relays were added for headlights, elect fan, and dual horns (all unswitched). The old coil wire energized the relay for switched circuits for ignition, elect choke and probably one or two other things.
I also completely rewired a '70 F100 with an E Z Wiring kit. I'll NEVER do that again!!! It'll be much easier to clean up any wiring messes the previous owners left you and add an expansion block for new circuits.
The 3G alternators have internal voltage regulators.
Old Aug 31, 2013 | 12:44 PM
Cracker289's Avatar
Cracker289
Something like this although I don't think 40 bucks is a good deal for it.
http://www.summitracing.com/parts/hla-h84988001
Old Aug 31, 2013 | 10:13 PM
orich's Avatar
orich
Like HIO Silver posted the 3g alternator has the built in regulator system..and it's an ez install....orich
kmcg
35
Dec 22, 2021 03:50 PM
glust
Apr 29, 2017 07:03 PM
bc4x4f250
Electrical Systems/Wiring
Apr 28, 2014 04:04 PM
cwp_edwards
Feb 21, 2010 09:45 PM
Violjohn78
28
May 20, 2006 09:30 PM
