Dana 60 question
Old Aug 30, 2013 | 08:28 PM
rockittsled's Avatar
rockittsled
Dana 60 question
5. Remove the wheel lock nut, lock
washer and wheel bearing adjustment
nut, using Tool T7OT-4252-D or
T7OT-4252-E. Under no condition
should the lock nut be removed with
a chisel. Discard the lock washer.
taken from ford service man. what are those tool numbers equivalent to?
Old Aug 30, 2013 | 08:55 PM
march's Avatar
march
I'm guessing that those numbers refer to the spindle nut socket. Available at the local auto parts place. 2.5" I believe.
Old Aug 31, 2013 | 01:27 AM
rockittsled
going on napa, it says 2 9/16in..... same nut and specs on oreillys site
http://www.napaonline.com/Catalog/Ca...102_0415359148
I have seen the 2 1/2in number on other threads on the forum ......
am I looking at the wrong item? I want to remove the drums to ck brake shoes and drums
Old Aug 31, 2013 | 01:33 AM
montana_highboy's Avatar
montana_highboy
2-9/16 is the correct size...
Though a 2-1/2 could be made to "work".
The cost is the same.....just buy the 2-9/16
Old Aug 31, 2013 | 01:52 AM
rockittsled
thanks
Old Aug 31, 2013 | 01:56 AM
montana_highboy
Originally Posted by rockittsled
thanks
No problemo...
Last time I bought one (10-12yrs ago) it was like $10 at Napa
Old Aug 31, 2013 | 02:14 AM
rockittsled
$17 to $25 now depending on brand
Old Aug 31, 2013 | 02:17 AM
montana_highboy
Ouch! prices have went up...
It's one of those 1-2 use tools, you'll lend it out more than you'll use it (unless you're a mechanic)
So i'd just buy the cheapest....
Old Sep 1, 2013 | 05:30 PM
Scoop531's Avatar
Scoop531
2 9/16 is correct I just did mine someone put nice lol hash marks in mine with a chisel already so I used a flat head and just gave it 2 taps and it spun by hand
Old Sep 1, 2013 | 05:45 PM
Laser_Target's Avatar
Laser_Target
I used a large flat head screw driver on mine because previous owner already had big groves in the nut. Then I replaced it with the Locking nut (all one peice) type from the J-yard instead of the 2 nut and tab locking washer type that was on my 79.
GregN
Oct 3, 2025 03:53 PM
edford1
Jul 6, 2014 10:00 PM
Copedawg
13
Jan 24, 2011 02:59 PM
jpj64
1983 - 2012 Ranger & B-Series
39
Mar 13, 2008 10:02 PM
luvrocks
Feb 19, 2008 09:34 PM
