inline tubes
Old Aug 30, 2013 | 01:28 PM
rlb652_674's Avatar
rlb652_674
Talking inline tubes
This old man is still learning to be very carefull when speaking to sales people!! I should know better by now! I talked to 2 sales people at inline tubes and was given the wrong information both times! I was looking for the right front brake line - on my 77 it is the one with a hard line as part of the rubber going to the caliper - and of course they did not have it. We decided on going stainless and it seems I did not use the term "braided" so I was given a part number for all the hard lines to order. Not what I needed. The second time I called I asked if they had to make the lines - again I did not use the term "braided" - and was told they were in stock. Now I am told that is not the case and of course they do not take returns. So - when talking to inline tubes be very carefull you make sure the sales person knows what you are looking for!! If you need stainless steel lines to replace your rubber make sure you use the term "BRAIDED lines"!!!
Any body in Seattle need some stainless steel hard lines for their truck??
Last edited by rlb652_674; Aug 30, 2013 at 01:35 PM. Reason: adding more information
Old Aug 31, 2013 | 09:08 AM
lafermedavid's Avatar
lafermedavid
in-line tube
With inline tube ,I beleive you can send a pattern or original brake lines for an exact copy.I have a question for any one that has used inline tube.On my highboy my rear axle tube ,breather and three way brake line port,Has any one sent theirs to inline,to have the braided line cinched.I sorta dont feel good sending that away,just thought Id ask.Does that verticle brake line un- screw from that block
Old Aug 31, 2013 | 10:20 AM
Blue and White's Avatar
Blue and White
I worked with Inline on a hot rod project. I had a set of lines from another vendor that did not fit my custom setup. After talking to Inline, I made a mock up of what I needed by simply cutting the lines I had and slipping some fuel hose over the brake lines. Once length and fitting orientation was correct I put hose clamps over the fuel hose and sent it in to Inline. They sent me back a perfect fitting set of stainless braided lines. I was happy.
Old Aug 31, 2013 | 11:06 AM
lafermedavid
brake block
( Pic courtesy of Mike O) is that block still available new?
Old Aug 31, 2013 | 01:11 PM
rlb652_674's Avatar
rlb652_674
Have to agree that if you want the right replacement item it is best to send either a very detailed picture or the actual item! No matter who you order from!
Or do it yourself if you have the skill and tools.
The reviews at other forums for classic tubes Classic Tube, Preformed Tubing supports a much better customer service attitude. Chris at inline tells me that if I ship the hard lines back they will send me the braided lines I was originally looking for. I am leaning towards doing that. Likely better than just eating $230.
Old Aug 31, 2013 | 01:47 PM
lafermedavid
in line
Chris at inline tells me that if I ship the hard lines back they will send me the braided lines I was originally looking for. I am leaning towards doing that. Likely better than just eating $230,,,,,,Wow thats Great,thanks for your post,,,didnot mean to steer away your topic just new it would get attention with the title of inline,,,so Im at where your at,its just that darn rear brake block has me
Old Aug 31, 2013 | 02:12 PM
rlb652_674's Avatar
rlb652_674
Sure looks like there is no way to unscrew the line from the block. Suspect its all one piece. Have you talked to classic tubes? Now that I know better I would call them/send them the picture and ask what they can do. You could also call inline tubes and do the same. Just be sure they understand what you need!!!
Old Aug 31, 2013 | 03:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That block does not unscrew. The block is made to be crimped to the hose. Trying to unscrew it will destroy it (if it was still good).
Just an added note. I've always used Inline Tube for my project(s) and have always been pleased.
EDIT: The lines that you see in the picture that Lafermedavid posted of my frame are Inline Tube stainless steel lines.
Old Aug 31, 2013 | 04:01 PM
lafermedavid
rear axle block
ok Mike ,so did you send block to inline ,or were you able to find nos,my block works ,just would like to have hose replaced or purchase new block,thankyou
Old Aug 31, 2013 | 04:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Bought the line new from the local parts store.
They're still available over the counter. No need for custom made.
Old Aug 31, 2013 | 04:24 PM
lafermedavid
Thanks Mike,Thanks rib
Old Aug 31, 2013 | 04:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
NAPA p/n UP36851 rear brake hose 1977 Ford F150 2WD
Online price $13.99
Old Aug 31, 2013 | 05:39 PM
lafermedavid
rear axle brake and breather block
6" Extended Rear Axle Hose
6" Extended Rear Axle Hose (ok so it works in conjunction with a seperate breather vent that passes threw block that works on bolting unit down)
<!-- END store_header --><TABLE style="BORDER-BOTTOM: #666 1px solid; BORDER-LEFT: medium none; BACKGROUND-COLOR: #f5f5f5; BORDER-TOP: #666 1px solid; BORDER-RIGHT: #666 1px solid" cellSpacing=0 cellPadding=0 width="99%"><TBODY><TR><TD vAlign=top><FORM method=post action=http://broncograveyard.com/cart.php><INPUT value=add type=hidden name=action> <INPUT value=/bronco/c-254-front-brake-4wd-f250.html type=hidden name=return> <INPUT value=52548 type=hidden name=id> <TABLE width="100%"><TBODY><TR><TD style="PADDING-BOTTOM: 1em; PADDING-LEFT: 1em; PADDING-RIGHT: 1em; PADDING-TOP: 1em" vAlign=top width="99%">Item #52548 - New
1976-79 Ford F2509" Axle Breather Vent
1976-79 Ford F350
</TD></TR></TBODY></TABLE></FORM></TD></TR></TBODY></TABLE>
here is the bronco graveyard rear axle hose,although it does not specify breather built in as OEM
Old Aug 31, 2013 | 06:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
<!-- END store_header --><table style="BORDER-BOTTOM: #666 1px solid; BORDER-LEFT: medium none; BACKGROUND-COLOR: #f5f5f5; BORDER-TOP: #666 1px solid; BORDER-RIGHT: #666 1px solid" cellpadding="0" cellspacing="0" width="99%"><tbody><tr><td valign="top"><form method="post" action="http://broncograveyard.com/cart.php"><input value="add" name="action" type="hidden"> <input value="/bronco/c-254-front-brake-4wd-f250.html" name="return" type="hidden"> <input value="52548" name="id" type="hidden"> <table width="100%"><tbody><tr><td style="PADDING-BOTTOM: 1em; PADDING-LEFT: 1em; PADDING-RIGHT: 1em; PADDING-TOP: 1em" valign="top" width="99%">
</td></tr></tbody></table></form></td></tr></tbody></table>here is the bronco graveyard rear axle hose,although it does not specify breather built in as OEM
Actually, the breather isn't an integral part of the brake hose, it's a separate part similar to a bolt. It also is used to hold the block in place and most have a 7/16"-20 thread.
Lafermedavid, if your breather doesn't come out, more than likely dirt or corrosion has built up and is keeping it from pulling out of the block.
Another FYI. The actual breather hole is pretty small and clog up very easily. Before you reinstall it, remove the hose and run a small drill bit through the breather hole. This will help avoid "mysterious" axle seal leaks.
Old Aug 31, 2013 | 06:48 PM
lafermedavid
inline tube
wow you would have never thought that was separate,looking at my 40 year old part,delima solved Brilliant,sometimes its the little things that trip you up,hope this helped others
