Need Some Help Please
Old Aug 30, 2013 | 01:13 PM
jerseydevil907's Avatar
jerseydevil907
I have a 2000 Excursion. It's a 7.3 diesel. Check engine light was on and I had to change fuel injectors 1 and 8. Took care of that. I've replaced them before and put everything back together no problem. Fuel pump is fine. I replaced the fuel filter, No air in the line, I replaced the cam sensor. She still won't start. It cranks and with starter fluid it will turn over but then shuts off. I am at a loss and my head is about to explode. Anyone have any ideas?
Old Aug 30, 2013 | 01:23 PM
kornfanjoe's Avatar
kornfanjoe
Post in the 7.3 forum for better results
Old Aug 30, 2013 | 01:42 PM
Magnus E's Avatar
Magnus E
Oil pressure? Could be the high pressure oil pump.
Old Aug 30, 2013 | 02:09 PM
Stewart_H's Avatar
Stewart_H
Why?
Moving this over to the 7.3L PSD forum.
Stewart
Old Aug 30, 2013 | 04:30 PM
BlueScab's Avatar
BlueScab
Unplug the ICP sensor and try starting it.
Old Aug 30, 2013 | 04:44 PM
acf6's Avatar
acf6
Stop using starting fluid...
Old Aug 30, 2013 | 05:36 PM
hydro man 17's Avatar
hydro man 17
You could still have air in the fuel or oil systems. I have read many times that it takes some doing to get it all out enough just to start it. Even more running time to get it all out.
Old Aug 30, 2013 | 06:01 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Keep the starting fluid away from it! Glow plugs and starting fluid can cause major damage!
Is the HPOP reservoir full?
Do you get the Wait To Start light when the key is turned on?
Are the batteries fully charged?
Oh, And welcome to FTE!!!
Old Aug 30, 2013 | 06:08 PM
jerseydevil907
Thanks for all the input. I will try everything tomorrow when Florida weather permits. Hate those afternoon storms.
Starting fluid? Sucks that's what auto zone gave me. And yes he knew it was
diesel
Old Aug 30, 2013 | 06:11 PM
acf6's Avatar
acf6
Sounds about right for autozone.
skyler530i
Apr 4, 2018 05:08 PM
JimBowie
Dec 21, 2012 11:45 PM
LoyBaird
Jul 23, 2012 10:14 AM
Opey12345
Mar 25, 2009 09:51 PM
ranlyn54
Jun 6, 2004 01:30 PM
