1990 no fire
Old Aug 30, 2013 | 08:00 AM
halaferd's Avatar
halaferd
1990 no fire
Found a 1990 2wd reg cab ranger with the 2.9 and 5 spd for $600 today. The owner says it isn't getting fire to the plugs and when putting new flywheel in, he broke the hydrolic line for the clutch.
I'm decent at doing my own repairs and want a light truck to drive to work. So this seemed up my alley.
Just wanted your opinions on this, as I have never fooled with these trucks.
Old Aug 30, 2013 | 12:20 PM
pawpaw's Avatar
pawpaw
If no spark, the ICM belongs on your suspect list, its a common problem part, as its mounted under hood, usually on the side of the distributor, or the passenger side inner fender well, so it gets wild temp swings & cooked by engine heat.
If that checks out ok, maybe have a look at the coil.
As this has a distributor ignition, have a good look inside the distributor cap at its rotor spark lugs, for excessive wear/gap or corrosion on them & at the rotor for signs of break down/carbon tracking inside, where it fits onto the distributor shaft. Motorcraft cap, rotor, wires & plugs are recommended, as they are designed for our ignition system, fit right & are of good quality.
Replacing the hydraulic clutch line shouldn't be too bad, but bleeding the system can be troublesome. Do a forum search on how to remove, hang up & bench bleed the system before installation, as it could save a good bit of time & frustration trying to bleed air from the system.
Some thoughts for consideration, let us know how your resurrection quest goes.
Old Aug 30, 2013 | 05:05 PM
03 Maz B23's Avatar
03 Maz B23
check to see if timing belt is intact.
Old Aug 30, 2013 | 08:00 PM
pawpaw's Avatar
pawpaw
Good idea, but the 2.9L has a chain!!!
Old Aug 31, 2013 | 04:43 AM
03 Maz B23's Avatar
03 Maz B23
Thanks Pawpaw. I didn't look at the engine size close enough before posting.
Old Aug 31, 2013 | 04:55 AM
halaferd's Avatar
halaferd
Thnks guys for replying. However the seller failed to pay their phone bill and therefore I can't contact them to buy said truck.
BUT I do intend to find one to buy so this info will be great at that time.
TGH
1978 - 1996 Big Bronco
Jul 27, 2016 11:43 PM
lawsonej
May 31, 2016 07:40 AM
Fett
Jul 24, 2010 05:45 AM
irishguyincc
18
Apr 7, 2006 06:02 AM
Bogus
Jun 9, 2004 07:27 PM
