Clutch sensor
Old Aug 30, 2013 | 07:35 AM
ALedbetter1's Avatar
ALedbetter1
Clutch sensor
My friend has a 1989 f-250 with the 5.8 motor. Its a 4wd with the manual transmission. His sensor that says whether or not the clutch is pushed in so that it will start has quit working. These are fairly expensive new so is there anyway to just bypass it or is he going to just give in and bu one?
Thanks
Old Aug 30, 2013 | 06:35 PM
tjc transport's Avatar
tjc transport
i ain't rite
$22 buy it now with free shipping on ebay.
New Clutch Interlock Switch F150 Truck F250 F350 Ford F 150 F 250 F 350 99 1999 | eBay
Old Aug 31, 2013 | 11:44 AM
'89F2urd's Avatar
'89F2urd
I cant stand clutch switches, I bypass them on all of my vehicles. the one on these trucks are a pita relative to other vehicles. you need to tie the power wire (believe its the red one [with blue stripe?]) with the switch feed. im not sure which one is the switch feed off hand, an easy way to confirm is to use a jumper wire across the hot wire (unplug the harness), and to the others successively while holding the ignition in the start position. when it starts, that's the wire you have to tie.
Old Sep 21, 2013 | 08:41 AM
ALedbetter1
Thanks I was able to bypass it and for those who might use this post for future refrence it was the red wire with a blue stripe and the purple wire. You guys made this a fairly easy fix and for this I am grateful.
Old Sep 21, 2013 | 09:07 AM
'89F2urd's Avatar
'89F2urd
yea F that clutch switch. glad it worked out and glad ya came back and finished off the thread for reference.
snaponprofile
Aug 26, 2011 03:47 PM
dgrant09
Electrical Systems/Wiring
Mar 16, 2008 11:44 AM
BinaryWhisper
Dec 22, 2005 11:23 AM
johnsdiesel
29
Oct 26, 2005 04:57 PM
dstevenson
Jun 1, 2003 10:35 AM
