1st 5th tow coming up soon, anything (Superduty) to beware of?
#76
#77
#78
If you are going to repair the roof yourself with eternabond, I was told by a RV repair shop in Elkhart, In, to be sure and calk around the edge of the eternabond so that the edge does not lift and get dirt under it, and eventually come loose. Very nice rig. The leveling jacks are on my wish list.
#79
Sam, Click this link Dicor Patchit Kit - Dicor 402PR - Roof Maintenance & Repair - Camping World. This stuff works great to fix rubber roof tears. I caught some trees years ago and patches are still holding tight. Costs way less than your insurance deductible. Mike
stuff to adapt my 60 amp welder service to 50 amp rv service, so I can run the a/c.
and a dehumidifier.. windows open now, and tarps off to dry in the sun!..
Sam
#80
thanks for the reminder
#81
seems I might have a problem with mine. in the rain, the left front leg retracted some.. not sure why.
when the back dries out some (should have pulled it closer to the house on the rock road), I'll pull the trailer up and test it out again.
the dually is holding the trailer up at the moment.. and I expect we'd cut 12 inch deep ruts if I tried now!..
#82
#83
roof is repaired, dehumidifier running.. only got about 1/2 cup of water off the carpet with the carpet cleaner vac.
We just picked up the unit in Michigan on Monday 9/16. So just drove home and stopped on the way.
we have a few trips in mind.. some family and some not. My Mom turns 100 in the spring, and it will be nice to have the trailer available.
want to see Yosemite, and that largest ball of twine!..
#85
#86
mine is supposed to be 12'8" to the top of the front A/C.
#87
to measure height, I used a 3 2x4's and a level. I clamped (2) 2x4's together to make a vertical piece that was over 14' long. Then I set the third 2x4 on top the highest point on my trailer (happens to be the front A/C unit). then I leveled that 2x4 against the plumb (vertical 2x4's) and camped it together so transfer the height over the to the vertical 2x4's. I then measure to from the bottom of the clamped 2x4's to the horizontal 2x4 mark that I transferred on to it. Mine is 13'-4" so I need to be careful.
#88
#89
#90
