52 Ford Seam Sealer question?
Old Aug 29, 2013 | 05:54 AM
52' fordnut's Avatar
52' fordnut
Hi,
I had read up on this quite a while back but I still have some questions regarding the seam above the rear window of the 52 Ford cab.
I think, from what I read, that I may go with a paintable 3m body sealer. Does anybody have any suggestions for a better sealer for this seam?
Also, I know this may be a weird question, but this is my first truck restoration....
Which side does the seam sealer go? Inside or outside?
On my 52 on the inside of the cab you can see remnants of the original sealer. So that's why I'm curious as to whether it goes on the inside or outside. I want to think you apply it on the outside but the remnants on the inner part have me befuzzled.
Any help is always greatly appreciated! Thank you all so much.
Jon Preston
Old Aug 29, 2013 | 09:08 AM
tinman52's Avatar
tinman52
Welder User
I used a good quality autobody seam sealer (Lord Fusor)on the outside. Clean out the seam to bare metal make sure to get all rust and crud, prime with epoxy primer or similar, then seam sealer. Shape it with your finger wetted in water or thinner. This will leave only a faint line when painted. Not necessary to seal the inside unless you want to.
Old Aug 29, 2013 | 09:39 AM
52 Merc's Avatar
52 Merc
Scott's advice is spot on. While you're doing it, don't forget the 2 small seams at the belt line on the cowl, just below the windshield corners.
Lukes66
42
Jun 24, 2019 01:56 PM
Marty Smilt
Oct 2, 2010 01:41 PM
dadwood
Jul 4, 2010 08:33 PM
Earl
31
Jul 3, 2006 08:56 PM
nsaikia
Paint & Bodywork
Jun 8, 2005 09:16 AM
