1937/48 Ford Passenger Cars / 1937/51 all trucks.
------------------------------------------------------------ 2C-11500-A .. Starter Button (Motorcraft SW-287) / Available from Ford
1952/55 all trucks / Used as the windshield washer switch on 1965/66 F100/250's, 1966 Econolines.
Ignition and starter button are different. The truck still had an ignition key switch that needs to be turned on then the starter button pushed. In 51, the starter button was chromed metal. In 52, the starter push button was black plastic, same as the dome lamp switch in the door jambs on Extra equipped trucks.
