Maybe you guys can help..
Old Aug 28, 2013 | 01:26 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Hey all, in the process of getting my DP-tuner re-flashed for my truck. I replaced a couple injectors a month ago, in #8 and #4 with AD's, Clay at RiffRaff said it would work since I have the FRx installed. Here's the problem, I'm getting an intermintent ses light, seems to go away after it's warmed up. Justin @ DP wanted to know the code but I don't have AE. I'm guessing at this point but it's probably a soft code.
Thanks for any help in this matter, Bill
Old Aug 28, 2013 | 02:11 PM
01PS's Avatar
01PS
Without pulling the code there's not a lot to be said. Are you driving while this happens? Are you hard in the throttle? Anyone near you with AE or similar than can pull the codes for you?
Old Aug 28, 2013 | 02:31 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
I would go by a auto parts store or dealership and have them read the codes. They don't use AE, but it will help knowing what it is. Do you have or know anyone with a flash programmer. SCT,Edge, Hypertech, etc...
If it pops up again and goes away do not unplug the batteries. It will reset the code(s) until it comes on again.
How long does it take for the light to go out? A few seconds or several minutes?
~Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Aug 28, 2013 | 02:32 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Yes usually driving, not hard on the throttle. No one near with AE but there's a diesel performance shop about 35 miles from me I tried to call. Will keep after them.
Old Aug 28, 2013 | 02:34 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
~Diane
Light goes out after a few seconds, seem to come on with a little throttle.
Old Aug 28, 2013 | 02:35 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Also, check out the Ohio chapter on here a few doors down to see if anyone closer can read the codes for you.
__________________
Old Aug 28, 2013 | 02:49 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Thanks, will do
Old Aug 28, 2013 | 05:13 PM
tappit01's Avatar
tappit01
Thanks, will do
i might be pretty far south of you but, i have a/e if your ever down this way.
Old Aug 28, 2013 | 06:39 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Thanks, I may take you up on that offer if this shop near me doesn't pan out.
Old Aug 29, 2013 | 03:45 PM
01PS's Avatar
01PS
~Diane
Keep in mind most auto parts stores will not have the tool to pull codes from your truck.
Old Aug 29, 2013 | 04:04 PM
kawcrasher's Avatar
kawcrasher
Where exactly are you at? I have a Superchips tuner that readers codes pretty well. I'm in the Akron area this weekend.
Old Aug 29, 2013 | 08:01 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Actually it will be better than not having anything at all. I send people to O'Reillys all the time and what they have is fine for reading codes. Cheaper than the dealership. Not good for data logging, but they can pull diesel codes. Just tell them you need it to read diesel codes.
__________________
Old Aug 30, 2013 | 11:12 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I tried the local O'reilly Wed. nite after work and he couldn't pull any.
After the thing is good and warm usually 20 min. or so, the ses light won't come on at all. I even tried mashing it going up a hill and it stayed off.
Old Aug 30, 2013 | 11:16 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I'm about 20 min. southwest of Mansfield, but have to work sat.
Thanks for the offer though.
Old Aug 30, 2013 | 10:44 PM
kawcrasher's Avatar
kawcrasher
If you don't get it soon, I end up in Shelby for a few minutes most days. Only problem is I only know a few hours in advance when I'll be there.
