I had to put new heads on my work truck this past weekend. While I had the heads off, I went ahead and replaced the cam synchro. After I get it all back together and make the first test run, I get a CEL and loose oil pressure. The new syncro failed, luckily it didn't do any damage, it just locked up the shaft and the gear kept turning. I placed the original one back on the truck to get home. Once home I replaced the synchro with a new one again. I put #1 on TDC 0 degree mark on the cranck pully, made sure I was on the compression stroke. I then placed the new synchro in place making sure the "tang was in the center of the opening with the alignment tool, and buttoned everything up. I cleared all codes, but on my way to the job the CEL came back on with P1336, which I understand is Crank and CMP out of sync. What did I do wrong. The truck seems to run fine, a little ping while underload. How do I get these back in sync? I am tired of looking at the CEL.
Sounds like you had the procedure right, did you check the crankshaft timing mark to make sure it was on TDC & that it didn't move????? Motorcraft parts are recommended, Dorman parts aren't, as many folks have reported bad results with them..
You were right pawpaw and I feel like a total idiot. I had my wife and son watching the crank pully, I showed them where the zero was, they would tell me when to stop. I set the synchro. up. Fire it up and BAM CEL again, each time. I knew I was on the compression stroke. So tonight I did it again myself, same thing. I gave up went in the house resigned to take it to the shop. After dinner I said, let me give it one more try. This time I took sand paper to the pully, and rubbed baby powder on it, and low and behold, I was setting the pully to 20 degrees instead of zero. I changed everything around again and WAMMO, no CEL and she runs great.
Alright, good feedback, way to hang in there & persevere to see this problem through to a positive ending. Good to hear all now seems well & your on the road again!!!!
