They're Here!
Here's the '52 first. Need to get a good shot of the engine later today.
Had a bit of a time getting this one on the trailer as it has what appear to be stock car rims on the rear. Seller had an engine hoist handy and jacked it up, drums were removed and rims were flipped, then it fit.
The first one looks like mine when I picked it up. At first I was wishing it was still assembled, but after spending a couple of hours getting a new set of inner fenders off of someones parts truck, I decided I was glad the PO had handled the seized bolts before I got it.
Good thing is, the frame has been blasted & painted, new front shocks, brake lines look excellent but hoses are cracked, and the engine has been rebuilt. The PO lost interest somewhere along the way. From a catalog in one of the parts boxes last night, it looks like he started in....1998!
Unfortunately it spent the last 5 years under one of those small tin-roof carports which kept it from getting hit by any branches, but didn't keep water out. The upturned fenders in the back bed collected leaves and rainwater, and rotted out in several places. Photos he included from before he moved it there showed nice fenders. Ah, well - he gave me an excellent deal and is a really decent guy.
That's a lot of old truck parts to park in front of your nice house. My wife would have shot me - just saying. So you are fixing up the '51 & parting out the '52? Be nice to your hood & doors - there aren't any reproductions being made. What's your plan? Full restoration, a weekender, hotrod?
You have a really nice start. Looking good over there in North Carolina!
(Raised in Chapel Hill - Go Heels!).
Ben in Austin
1950 F1 (351W/AOD).
You are fairly close by, I'm in Durham
Ben, if you look down around the 5th photo of the '52 passenger side, you'll see a large carport in the background currently holding a '51 Farmall Super A and a lot of junk. The '52 will temporarily move there soon, need to fix a flat front tire first. Got one fixed last night (leaky valve), the passenger side has a trashed sidewall. Think the PO pulled it up to his driveway with the tire flat. They're old and dry-rotted anyhow, just something to hold it up and move it around. The wife is pretty understanding. She let me raid the savings account to buy these with the understanding that I sell some of my other 'stuff' and put the money back in a month. The '51 will go down the road as soon as I have the parts swapped off that I want.
Will be restoring or more accurately, rebuilding the '52. It looks worse than it is due to a thin coat of rattle can primer which has long since turned to rust on the bed and doors. The bed is actually 6'. Both are F1s on their titles.
Definitely not looking to build a show truck. I want a clean, solid, straight daily driver. No desire to install a newer engine or to chop up the frame, though I may lower the front a couple-three inches and drop the back an inch, something like that. Will probably get some wider plain steel wheels for radials, painted black with chrome lug nuts. That's about as pimped up as it will get. So, mildly rodded if that's a description? I'm not above making improvements for safety and utility within reason.
The PO installed a new exhaust system but it's the original single pipe. I'll use it as is for now, but somewhere down the road it will get headers and dual glass packs (do they still make such a thing?) just for a better sound.
It came with three bagged electrical harness sections from Dennis Carpenter, so that's a big plus. Just need to get the cab pulled and done. It's a low priority project for a while, though. The Farmall has a cracked block and needs an engine swap as soon as I find a good one. Need to use it for mowing, which keeps the good wife happy of course. This is key to any successful project.
Here are a few shots of the rebuilt engine. It has about 2 hours on the rebuild. Just enough to burn the paint off the exhaust manifolds. Hasn't run in a while, though he had it running for a few seconds at a time last week. Something to putter with in the next few weeks as time allows.
Had a few more pictures to post but got interrupted by my daughter (9 months) letting me know she was hungry. Further explanation of why the truck is a low priority.
So here's a shot of the truck after fixing the driver's front tire valve and re-inflating, then washing it down to get the slime and crud off. Also some shots of the running boards. Was thinking they were trash but after washing them down last night it looks like I can patch them for now, maybe put steps over them until I can afford a new pair. Two of the holes were made to line up with the front stake holders in the pickup bed.
If patching doesn't work - they do make reproduction running boards in both fiberglass & steel. The steel ones are pretty pricey - around $300ea if I remember correctly. If you search on here you can see where guys have patched up their running boards - generally scavenging what they need from other crapped out ones.
Good luck over there. Ax in Durham is one of our more experienced guys - you'll want to soak up knowledge there.
Ben in Austin
1950 F1
