RABS
Old Aug 26, 2013 | 05:12 PM
broketruckjohn's Avatar
broketruckjohn
RABS
my 90 f150 has a carbuated 302 no computer my rabs light does not go out at all. the back brakes lockup easy. if i adjust them down so they dont lockup the pedal goes almost to the floor.all new brakes front and rear. if i cant fix it i would be ok with just normal brakes. any ideas
Old Aug 26, 2013 | 05:27 PM
MeanGreen460's Avatar
MeanGreen460
your truck does have a computer"I'm thinking you may need a rabs sensor .Its in the rear axle
Old Aug 26, 2013 | 06:15 PM
Conanski's Avatar
Conanski
Are you 100% sure you installed the rear brake shoes properly? There is a front and rear shoe which are easy to mix up(one is slightly shorter than the other) and if you put them on backwords or get both fronts on one side you will have the problem described.
Old Aug 27, 2013 | 06:08 AM
broketruckjohn
RABS
after double checking brake install am satisifed they are correctly installed. have changed the sensor on the axle.does the HCU on the frame rail plug into the comp.? this is a carburated point engine
e. the comp. fried (smoke and all).the wiring harness is cut at the firewall. it took some time to wire it back up all gagues and factory electronics work. but no antilock.
test1328
Nov 13, 2014 03:56 PM
B.Ruddick
23
May 15, 2009 11:58 AM
panteramatt
Dec 31, 2006 09:55 AM
hawk242
1978 - 1996 Big Bronco
Sep 13, 2005 03:02 PM
kespo
Aerostar
Sep 7, 2004 06:53 AM
