Torque App Readings, what do you think?
I took theses readings with The Torque App, while driving south on I-77 in Virginia pulling a very light load (a 6x12 UHaul with a few pieces of furniture). Please help me understand them. Also, how do I get EGT to read?? Hope these links work...
Attempt at posting pics with Google, removed...
This is actually the MAP code.
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code – get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 — FF74 (I USE THE “FF71″ FOR MY AREA, IT WORKS GREAT)
14.1 — FF73
14.2 — FF72
14.3 — FF71
14.4 — FF70
14.5 — FF6F
14.6 — FF6E
14.7 — FF6D
14.8 — FF6C
14.9 — FF6B
15.0 — FF6A
^^^^^This makes boost very accurate for where a person lives ^^^^^^^^^^
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
14.1 — FF73
14.2 — FF72
14.3 — FF71
14.4 — FF70
14.5 — FF6F
14.6 — FF6E
14.7 — FF6D
14.8 — FF6C
14.9 — FF6B
15.0 — FF6A
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
14.1 — FF73
14.2 — FF72
14.3 — FF71
14.4 — FF70
14.5 — FF6F
14.6 — FF6E
14.7 — FF6D
14.8 — FF6C
14.9 — FF6B
15.0 — FF6A
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
14.1 — FF73
14.2 — FF72
14.3 — FF71
14.4 — FF70
14.5 — FF6F
14.6 — FF6E
14.7 — FF6D
14.8 — FF6C
14.9 — FF6B
15.0 — FF6A
While there is an Intake Manifold Pressure gauge, I haven't tried it. Use the Turbo Boost/Vacuum gauge and then in your Vehicle Profile you can tune the boost for altitude compensation with a simple input. There also is an option under Units to limit the boost gauge from reading negative numbers.
