Power Steering/Door Locks
Old Aug 26, 2013 | 01:06 PM
wormshoe's Avatar
wormshoe
2006 F150 5.4 2WD extended cab tow package 24k miles
My power windows have stopped working from all locations. I checked and the fuses are good. I can no longer use the exterior keypad to unlock the truck, yet my remote keyring switch will electronically open both driver and passenger doors. Neither driver's nor passenger's interior door switches work. Does anyone have any ideas?
Thanks...wormshoe.
Old Aug 28, 2013 | 10:03 AM
wormshoe's Avatar
wormshoe
I forgot to add this to my original post: neither of my electronically controlled side mirrors work either.
Old Aug 29, 2013 | 05:38 AM
Norman Pyne's Avatar
Norman Pyne
You might have broken wires in driver's side door jamb. Pull the rubber back that goes from the door to the cab and check there first.
Old Aug 29, 2013 | 10:31 AM
wormshoe's Avatar
wormshoe
Thank you Norman. I will look at it this evening.
Old Aug 29, 2013 | 04:30 PM
cb_13's Avatar
cb_13
I agree with Norman. Have seen it multiple times. If you repair the wiring yourself be sure not to make your repair where the wire bends. If you do it will not last very long. Splice in so that the new wire is what bends and your splices have as little stress on them as possible.
Old Aug 29, 2013 | 05:16 PM
wormshoe's Avatar
wormshoe
Excellent suggestion sir! I appreciate both you and Norman jumping on board. I was getting closer to admitting defeat and bringing it to the dealer, but now there is a ray of hope. ;-)
This morning I tried it before leaving the driveway and nothing worked. No surprise. I stopped for coffee at Racetrac and tried it again before leaving....and everything worked except the keypad!? After driving another 9 miles, I tried it again and the door locks and power windows (all positions) worked. Left the marina about 1 hour later and nothing worked!
At that point, I was seriously considering having a drink...and I don't mean finishing my coffee. I will let you know what develops tomorrow. Thanks again to both of you. wormshoe
Old Sep 5, 2013 | 02:32 PM
wormshoe's Avatar
wormshoe
I've got some health issues and will wait until they pass before tackling this problem. Thanks to both of you.
wormshoe
Old Sep 21, 2013 | 10:43 AM
wormshoe's Avatar
wormshoe
Sorry about the delay getting back to you.
You were right about having a broken wire in the harness.
The ground wire (10 gauge) broke in the middle of the harness under the rubber boot. Perhaps Ford could have used multiple ground wires for the door's electrical loads or made the single 10 ga. ground wire more flexible by giving it more strands.
Thanks again for the diagnosis. You were spot on!
wormshoe
Tpap595
2009 - 2014 F150
Jun 30, 2017 03:05 PM
britteasy
1997 - 2003 F150
Sep 4, 2014 10:56 PM
beckman
Feb 20, 2014 03:09 PM
fdesorme
Escape & Escape Hybrid
Sep 7, 2010 07:05 AM
mercman78
2004 - 2008 F150
Aug 15, 2008 11:10 PM
