Vacuum Lines
Old Aug 24, 2013 | 02:44 PM
eureka16's Avatar
eureka16
Vacuum Lines
1990 E-150, 5.8L, EFI, TFI, EEC-IV
A work in progress... I have a code reader, check engine light is not illuminated. Codes 22, 42. Discovered Canister Solenoid Purge Valve tucked away with no vacuum lines connected. MAP vacuum line is connected to port on Throttle Body opposite side of TPS. There is another port above this connection which is capped. I am not sure why this is capped, or if MAP is connected to the correct vacuum fitting.
As for the CPSV, I know the inlet connection comes from the vapor canister. Where exactly does the outlet vacuum line attach on the intake manifold.
Appreciate any assistance from the technical guys, and gals can offer.
SCFlareside
Jul 1, 2018 04:12 PM
moonie2shoes
Nov 14, 2017 09:09 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Nov 3, 2017 04:58 PM
Junior Junior
Jan 17, 2014 10:41 AM
BigBlue92
May 24, 2011 10:09 AM
