Master or Slave Cylinder Problem?
Old Aug 24, 2013 | 02:28 AM
jjurva!'s Avatar
jjurva!
I have a 1960 F100. I got in my truck this morning to take it down to the muffler shop and when I pushed the clutch in the only pressure I felt was the pressure of the return spring. I checked for fluid in the master and it was empty. I didn't see any signs of a leak anywhere. I filled the master and still nothing. So is the Master or slave cylinder the problem. I don't want to order an 80 dollar part and find out that wasn't the problem.
Old Aug 25, 2013 | 08:33 AM
stuart1's Avatar
stuart1
Is there a rubber plate to be removed in the reservoir before fluid is added?
Old Aug 27, 2013 | 08:09 PM
jjurva!'s Avatar
jjurva!
More of a plug and to fill it I had to push the plug in instead of pulling it out.
Old Aug 27, 2013 | 08:20 PM
stuart1's Avatar
stuart1
Pull the plug OUT. Fill the chamber then reinstall the plug.
Old Aug 29, 2013 | 08:28 PM
jjurva!'s Avatar
jjurva!
I don't think I can. It has been tightened for such a long time the bottom of the plug is bulged so getting the plug out will be a difficult task. Also why would it make a difference as long as I get the fluid in the reservoir?
Old Aug 29, 2013 | 11:09 PM
stuart1's Avatar
stuart1
The plug is stopping fluid from entering the master cylinder. It must be on top the keep a constant pressure on the fluid.
By the sounds of it you need a new cylinder.
SiscoKid
Feb 21, 2013 07:43 PM
duckshepherd
1983 - 2012 Ranger & B-Series
Mar 19, 2011 02:01 AM
1988F-150
Mar 13, 2010 10:47 PM
MagKarl
Jul 4, 2007 03:53 PM
jjj_85
Jan 22, 2004 05:14 AM
