EGR Valve question
10-20-2013, 01:43 PM
on
EGR Valve question
I pulled the egr valve to clean today I noticed the I rings where bad so I got new ones they seem to fit a bit looser than the original ones. Is that ok
10-20-2013, 06:18 PM
on
I mean O rings. I went to auto zone and had them matched, but they seem to be a little more loose than the ones on there
10-20-2013, 06:22 PM
Personally I'd get the stock ones from Ford. JMHO.
on
You need the kit from Ford. I it comes with both orings and a graphite seal. Approx $17 bucks.
10-20-2013, 06:26 PM
Quote:
Originally Posted by
MoyockPowerstroke
x2 definitely what you need to do.
10-20-2013, 06:35 PM
on
Thanks, could I just unplug it for now since I put the not so good ones on there. I just don't want to screw the thing up. It would only be for about 20 min of driving
10-20-2013, 06:38 PM
Shure if it runs OK
it might let to much exhaust gas into the intake IDK might not run very good IDK try it
Iv tried to match oring before on things its Very Hard to do and get right
10-20-2013, 07:11 PM
on
Steadyman321
03-18-2013 07:33 PM
sparkkky
03-13-2011 11:26 AM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
10-06-2005 05:27 PM
JCastellaw
27
01-20-2004 08:04 AM
