steering box and pump fitting sizes?
I have a 78 bronco 400 6.6 custom that I've been adding bolt on aftermarket things to....just because. I've recently picked up a KRC cast iron steering pump that bolts onto the head (drivers side). It is equipped with 2 x's -6 AN fittings. I'm looking at dressing up the hoses and fittings anyways...but I can't tell what the other ends of the hoses should be. Can anyone help me figure out the fittings on the steering box? Fill in the blanks
Pressure Hose -6 AN to _____? I think the old one was a 3/8" o-ring to 5/16" inverted flare.
Return Hose -6 AN to ______? No idea.
Any Help would be appreciated!
I'm sure that Jegs has the measurements listed if you lookup the numbers.
EDIT:
Found those part numbers. 100700 and 100701. Be sure to mark which is the high pressure and which is the return. Bad things happen if you hook them up backwards.
