Sponsored by: Real Truck
Another problem
Old Aug 20, 2013 | 08:14 PM
4bigred's Avatar
4bigred
Another problem
While in Tow/Haul with my 5th wheel when slowing down probably at 5 or 10 mph the last downshift is very hard and the brake pedal gets real soft until full stop. Afterwards the brake pedal is firm. Tow/Haul without the trailer is fine. Any help is appreciated. Thanks I forgot to add it's an '06 F250 Supercrew 4x4.
Old Aug 21, 2013 | 06:09 AM
redford's Avatar
redford
FTE Leadership Emeritus
What engine do you have?
Old Aug 21, 2013 | 07:00 AM
4bigred's Avatar
4bigred
It's a 6.0.
Old Aug 21, 2013 | 04:37 PM
redford's Avatar
redford
Then I would first suspect a hydroboost issue.
Old Aug 21, 2013 | 05:11 PM
gandrimp's Avatar
gandrimp
What's the chances that the trailer brakes aren't working, your on the brakes hard, then the tranny downshifts hard (amplified by the hard braking), and then the tires slide just a little, which is then detected by the abs. That would soften the pedal, correct?
Old Aug 21, 2013 | 06:09 PM
4bigred's Avatar
4bigred
The trailer brakes are working. I tested them using the slide on the controller. I have the controller set at 8.5. The trailer is an Open Range RF337RLS.
Old Aug 21, 2013 | 09:18 PM
4bigred's Avatar
4bigred
Is there a test I can run to confirm a hydro boost problem?
rdenis
6.7L Power Stroke Diesel
21
May 4, 2017 11:53 AM
Canadian 6.0
Dec 3, 2007 09:23 PM
tomsold4x4
2004 - 2008 F150
Nov 29, 2006 11:34 AM
tfalk
Feb 8, 2006 03:45 PM
DFW1
Jan 31, 2004 06:45 PM
