General Diesel Discussion
Diesel Cooling Issue
Old Aug 20, 2013 | 03:46 PM
Rwazny's Avatar
Rwazny
Hi all thanks for my new membership..
My f250 gets hot relatively quickly when charging long grades at about 75mph and while pulling a 5000lb load on mild hills. any help is much appriciated!!!
2000 f250 7.3 diesel.
4" exhaust, afe intake, 35" tires.
i have installed the following in trying to fix it.
new belt (tensioner is good)
new fan clutch
cleaned the radiator fins, intercooler fins, and a/c condensor fins.
new water pump (not motorcraft) i know i should have!
new MC thermostat
radiator flowed fine when i cleaned it... i think!!
new coolant and additive
Edge CTS monitor
my monitor reads consitantly at 197-203 around town (75 degrees outside)
ANY THOUGHTS ARE MUCH APPRICIATED!!!
Old Aug 21, 2013 | 11:21 PM
parkland's Avatar
parkland
How hot exactly?
Old Aug 21, 2013 | 11:23 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Your cap may not be holding pressure. Replacements are inexpensive, might try replacing it and see if that helps. Only manual trans trucks have a coolant temp sensor that is monitored by the PCM. If you have an automatic, then the coolant temp value reported to your Edge is invalid.
Old Aug 22, 2013 | 12:40 AM
Pitcrw6's Avatar
Pitcrw6
Maybe a moderator can move this thread to the 7.3 section so more people can help you out even though Greg (shake-n-bake) is one of the best on here.
Old Aug 22, 2013 | 10:52 AM
Rwazny's Avatar
Rwazny
Hey guys sorry for the late reply work got a hold of me!
it has made it to 225 EOT on my cts... the stoch ECT guage went to red real quick after the cts hit 225.
I have replaced the cap with a stock cap too... ??
i have tried to feel the radiator after the engine is at full operating temp and it seems like the whole thing is evenly hot... there is also no diesel smell in the coolant. i am totally confused now!!
Old Aug 22, 2013 | 10:53 AM
Rwazny's Avatar
Rwazny
any guidance is appriciated!! this is my first time within your forum here... thanks!!
Old Aug 22, 2013 | 10:57 AM
Rwazny's Avatar
Rwazny
Morning Greg... my CTS is showing me the EOT. I have installed an ECT guage and it also seems to read almost exactly what my EOT is at all times after the engine hits operating temp. thank you for the reply and any further ideas. this truck is bad to the bone except for this one issue!
Old Aug 22, 2013 | 11:01 AM
Rwazny's Avatar
Rwazny
Originally Posted by parkland
How hot exactly?
Hey Parkland thank you for the reply. it has made it to 225 on my cts EOT guage. then the stock ECT guage went to red quickly. My aftermarket ECT guage seems to mirror the EOT of the cts now that i have put that in.
Old Aug 22, 2013 | 12:04 PM
parkland's Avatar
parkland
Maybe need a chemical cooling system flush?
Have you or can you verify the sensor using a laser thermometer?
Old Aug 22, 2013 | 12:20 PM
Rwazny's Avatar
Rwazny
I do not have a laser Thermometer... is that the one you point at a specific hose and it tells you the temp? i am down to try anything at this point! i like the 213 F250 but i do not want to have a payment. is a chemical flush what a radiator shop might do?
Old Aug 22, 2013 | 12:22 PM
Rwazny's Avatar
Rwazny
do you think i should try replacing the lower radiator hose? i have read that it will sometimes collapse when under too much pressure... ?? it seems like i can squeeze it relatively easy but i just dont know...
Old Aug 22, 2013 | 01:00 PM
parkland's Avatar
parkland
a laser thermometer is IMHO an invaluable tool.
Just point it at something, and it tells you the temperature.
For EG, if the truck is overheated, and you pull over, the rad should be relatively hot, every part of it.
If you found cool spots, it probably means it's plugged up.
You can also track the heat in hoses and such, to verify everything is working as it should be.
You can also use it to make sure the engine doesn't have any major hot spots.
Also to verify the sensors seem to be working.
Old Aug 22, 2013 | 04:33 PM
Rwazny's Avatar
Rwazny
ok i will go pick one up then to see how things are flowing. seems like i have no cool spots in the radiator but i have limited access between all the goodies in there. i will keep you posted! Thank you for the time you have spent with me.
James Charles
Modular V8 (4.6L, 5.4L)
Jun 25, 2018 12:31 AM
maxine
Jul 21, 2015 12:27 AM
chaoscreature
Jul 4, 2006 12:06 PM
ReloadX7
May 29, 2006 10:10 AM
zedx9
Nov 12, 2005 02:30 PM
