Help Needed Removing Panel Hinges
Old Aug 20, 2013 | 02:40 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I have been trying to remove the plugs covering the nuts/bolts that hold the hinge to the back doors.
[IMG][/IMG]
Anyone know how these are removed? Can't find it in the 56 repair manual or on the Internet
[IMG][/IMG]
Tried a chisel and hammer but nothing's moving
Old Aug 20, 2013 | 03:40 PM
Kurt G.'s Avatar
Kurt G.
They look like maybe splined press in going through the hinge and bolting inside. is that possible?
Old Aug 20, 2013 | 04:02 PM
bjmayberry2
I can't get to the back there's a plate between them and the outside door skin. I thought they were just caps but I've beat on them with a chisel and hammer and can't get them to move at all. I gotta believe Someone has had to remove the hinges before me. DR Smith says his PO cut them off I can see now why that may have happened
Old Aug 20, 2013 | 04:28 PM
Kurt G.'s Avatar
Kurt G.
mid fifty just shows hinge pins
Old Aug 20, 2013 | 04:45 PM
bjmayberry2
Yeah check out my hinges (post 1) the bolt is loose so I'm pretty sure hinge pins aren't gonna help I was going to take them off and see if someone could fix them. But I found out now it isn't an easy task
kraylake
Jan 18, 2021 04:23 PM
EXv10
Nov 19, 2018 03:36 AM
JonathanN
150
Sep 7, 2016 02:34 PM
Twitchyleprechaun
Nov 16, 2014 01:28 PM
gdub
Sep 26, 2011 10:22 AM
