I have an early model (built prior 7/96) 1997 Ford F150 and have been looking for the new clear type euro corner lights and every aftermarket parts dealer I have contacted only sells the late model 1997 lens.
The early model 97 corner lights do not have the 2 metal posts that attached itself to the frame bracket. The early model are screwed in the bracket with two screws.
hey bro, i had the same problem as you. There is one website that sells the lights for our truck. the site is procarparts.com
here's the link that goes directly to the lights that you need to purchase. They sell both versions of the clear corners. At one point I accidently bought the wrong ones cuz i didn't know there was a difference. So, now by process of elimination, i was able to find and order the correct ones. Here's the link that you need to use.
