Sponsored by: Real Truck
Surging engine
Old Aug 20, 2013 | 12:38 PM
REPHOTO's Avatar
REPHOTO
Surging engine
2006 6.0 Super Duty 4x4 Auto
Got in the truck today, cranked the engine and started playing with the radio when all of a sudden the engine started to slow down about 100 RPMs and then it reved to a little over 1000 RPMs. It continued to do this so I put it in gear and started driving. No more surge. I stopped at a traffic light and with my foot on the brake it would slow to about 500 RPMs and surge to A little over 1000.
Any ideas or help on this?
Thanks in advance
Old Aug 26, 2013 | 08:00 PM
1977scoutii's Avatar
1977scoutii
Thanks in advance
I just had the same issue:
Changed fuel filters - no change
Upgraded to new fuel pressure regulator "blue" spring - no change
Blew out air filter and cleaned ICP connector- problem resolved - leaning towards ICP connector
Old Aug 26, 2013 | 08:41 PM
REPHOTO's Avatar
REPHOTO
Thanks. I will look at that. However, since that day the problem has not resurfaced. That's a good thing, but scary, because you never know when and where it will happen again. Intermittent problems are the worst.
Thanks again.
Old Aug 26, 2013 | 08:55 PM
Misky6.0's Avatar
Misky6.0
Running the 6L you should have an odb2 gauge readrr, like the scangauge2, or newer smartphone apps. They let you monitor injector pressure and other essential data so when things like this happen you can often seen what is causing the issue. Otherwise you pay the shop and/or buy parts until you get the right one..
Old Aug 26, 2013 | 09:17 PM
REPHOTO's Avatar
REPHOTO
I have an obd2 code reader. Is a gauge reader the same thing or something different? My obd2 reader has not picked up any codes as of now. If the gauge reader is something different, where do you get one and how much do they cost?
Thanks
Old Aug 27, 2013 | 09:27 AM
1977scoutii
Thanks
Mine did not throw codes either. Since, I bought a scangauge II. Now I can monitor my ICP and IPR, which I believe was my issue. Also, more importantly, I can monitor my EOT and ECT.
Old Aug 27, 2013 | 09:53 AM
REPHOTO's Avatar
REPHOTO
Did the ScanGaugeII show any codes?
Old Aug 27, 2013 | 10:45 AM
1977scoutii
Well, yes, but not related to the surging. Don't have the code numbers, but one was for glow plug #6, which when I pulled it, omed it out, it showed infinitiy. Replaced, and problem resolved. The other was my fuel sender. It drops out at 5/8 tank, then resumes normal operation. I jacked the bed up, pulled the sender, cleaned the variable resistor PCB, and fixed that problem.
Again, did I have codes, yes, but nothing related to the surge.
I've only had this Scangauge II for two weeks, but can't imagine now running this truck without it. Typical gauge set up in these vehicles is BS (Oil Pressure, Trans temp, Engine Temp, boost, and gas gauge). Practically flying blind! I've got twenty more "gauges" programmed into my scangauge now.
Old Aug 27, 2013 | 11:55 AM
REPHOTO's Avatar
REPHOTO
Thanks everyone for all of the info on this problem. As I said earlier, it only happened that one day. I haven't done anything as of yet, because at present, I no longer have a problem. Kinda like, "If it ain't broke, Don't fix it".
JNC32
15
Jun 19, 2017 08:37 AM
genesiss
22
Oct 26, 2014 04:07 PM
mahd776
Feb 1, 2014 08:53 AM
mahd776
Jan 30, 2014 06:20 AM
guthrie&co
Feb 8, 2009 12:54 PM
