lifts??????
Old Aug 19, 2013 | 11:46 PM
sitInHigh's Avatar
sitInHigh
lifts??????
6inch lift on my f250 7.3.. Procomp how is that lift??? anyone no
sitInHigh's Avatar
sitInHigh
also can i fit 37s on this???
Old Aug 20, 2013 | 05:20 AM
JOHN2001's Avatar
JOHN2001
Tire height I believe will work. You may be worried more about how wide at that point. I run an 8" lift with 38x15.5s and I had to cut and trim. At that point they still rub the springs. My old 36x14.5s also rubbed the springs.
Old Aug 20, 2013 | 08:08 AM
joeyd61's Avatar
joeyd61
don't know about pro comp personally.I run 6" BDS lift with 37/13.50/20's, they will rub the spring on a lock turn and catch the inner finder if turned just right and hit a bump.
Old Aug 20, 2013 | 04:21 PM
sitInHigh's Avatar
sitInHigh
Yes I think im goin with 37 on 20inch rockstars. Just don't now how wide. I like the wide look alot tho.. and I may look into the BDS lift. Also one question what dose the 'avgjoe' charge for instalation for a lift like that?
Old Aug 20, 2013 | 04:35 PM
joeyd61's Avatar
joeyd61
when I got mine the 6" lift was 1800. At first I was going to attempt it but after talking to the place I got it from, They quoted 2200 out the door..I couldn't resist.
Old Aug 20, 2013 | 05:34 PM
JOHN2001's Avatar
JOHN2001
BDS is the way to go just for the warantee. If your riding on 3:73 gears and you pull you may want to think about gears. There's gonna be a huge difference. If you've got 4:10s I'd roll with it. Also a tire that big is going to throw your speedo off which will throw the way your Trans shifts.
Joey it seems like you and I are always the first responders when it come to lift questions.
Old Aug 20, 2013 | 08:48 PM
sitInHigh's Avatar
sitInHigh
400 to installll!! thats a deal where can i find that lol ahah
Old Aug 20, 2013 | 08:50 PM
sitInHigh's Avatar
sitInHigh
sweet !! great info! lots help guys. when shes lifted ill post some picks
Old Aug 21, 2013 | 08:09 PM
JOHN2001's Avatar
JOHN2001
I don't know if you have bought your lift or not or are set on going with procomp but I just came across a 5% off coupon code for BDS it's dp3q13 hope it helps the code is good until December 31st of this year. That's at www.jackit.com 888-846-4709
Vince79vette
Mar 29, 2014 01:47 AM
LedheadELH
Sep 10, 2010 07:56 PM
bleeding blue
Dec 27, 2009 11:33 AM
FordGuy1280
Sep 22, 2006 07:26 AM
pilot815
1978 - 1996 Big Bronco
Sep 8, 2004 03:46 PM
