Rear Differential
Old Aug 19, 2013 | 07:46 PM
dieselsubmariner's Avatar
dieselsubmariner
Rear Differential
How hard is it to change the rear gears? I have 4:10 gears and do not like them.. if anybody has the 3:55 (i guess thats what they are) and want to trade they can feel free and come over and swap them out.. i wont charge anything
Does anybody know, where to get a different set ?
Old Aug 19, 2013 | 07:52 PM
ReBilld's Avatar
ReBilld
Where are you located Stefan. I've got a 3.55 gear set.
Old Aug 19, 2013 | 07:58 PM
dieselsubmariner
Area code 39560
Old Aug 19, 2013 | 08:07 PM
ReBilld's Avatar
ReBilld
You're in Mississippi. You have to get the rear end shimmed right when you change the gear set. If not, it will destroy the gears.
Old Aug 19, 2013 | 08:27 PM
dieselsubmariner
Is there somewhere a good write up on a how to ?
Old Aug 19, 2013 | 08:41 PM
ReBilld's Avatar
ReBilld
Don't know of any good write ups, but I have used these shims http://www.ebay.com/itm/FORD-10-25-STERLING-10-5-REAREND-CARRIER-SHIMS-RMS-SUPER-SHIM-KIT-NEW-/330855928015?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4d088cd0cf
Old Aug 19, 2013 | 09:01 PM
95350PS's Avatar
95350PS
How much do you tow? Considering its a dually 4.10s are gonna be better for you. I love the 4.10s in my dually mileage isn't affected that significantly to justify me buying or even going through the hassle of a gear swap.....its something of you don't have or know how to work a backlash gauge you shouldn't attempt on your own
Old Aug 19, 2013 | 09:06 PM
dieselsubmariner
i do not tow a lot.. the max i ever tow, might be a camper, less than 9000lbs. I just do not like the high RPM on cruising speed. about 2300 at 65
Old Aug 19, 2013 | 09:09 PM
glovemeister's Avatar
glovemeister
I run 3.55s and 35" tires. I don't care for it at all. But they would work good if you run smaller tires like you want to.
Old Aug 19, 2013 | 09:10 PM
95350PS's Avatar
95350PS
Yeah that's about right I'm running 2250 at 65 I think if I remember correct the 355s are still gonna be 2000 rpm at 65 I guess I don't wanna spend 500+ with install to drop 250 rpm
Old Aug 19, 2013 | 09:13 PM
dieselsubmariner
mhh.. thats all im gonna be dropping? i was hoping to be around 2000 at 70
Old Aug 19, 2013 | 09:14 PM
95350PS's Avatar
95350PS
I could be wrong but I thought I read that in a thread awhile back
Old Aug 19, 2013 | 09:25 PM
95350PS's Avatar
95350PS
Ok I did some searching for you a guy with stock tires ran 2050rpms at 65 with 4.10s and put in 355s and ran 1750 at 65.....so you will drop 300 rpm on stock tires which I would think would be the same 300 rpm drop with any set up if your just changing gears
Old Aug 19, 2013 | 09:30 PM
dieselsubmariner
i can live with 300 rpm.. now i just got to find somewhere some good instructions
Old Aug 19, 2013 | 09:50 PM
cowmilker08's Avatar
cowmilker08
I researched this a while back when I was considering a gear change, and you will spend more on the proper tools to do the job right than you will on parts. Also it sounded very difficult to do, like somewhere between rebuilding an engine and rebuilding an automatic transmission. I decided it wasn't worth attempting it myself. I figured I could do it, but it just wasn't going to be cheap or very quick by time I figured out how to do it.
Its more expensive, but have you looked into an auxillary transmission? Race, performance & street cars, engines, engine parts, trailers for saleI suggest that because towing even 9000 lbs. isn't very fun with 3.55 gears.
