This is a condensor, right?
Old Aug 19, 2013 | 05:08 PM
turbogus's Avatar
turbogus
Hi gang, ltnp!
I've just replaced my secondary battery in 'Easy Bake' my '81 E-150 panel Econoline w Duraspark II ignition. Over the years each time I move the primary battery to the secondary position I'm reminded by that yellow condensor wire dangling behind the headlight.
Where would the loose end connect to?
Thanks and a lift of the lynch lid.
Gus
Old Aug 19, 2013 | 06:09 PM
fmc400's Avatar
fmc400
MSEE
That's correct, it's a "condenser," although the proper name is "capacitor." The term "condenser" is obsolete. It's a noise suppression capacitor; its job is to keep transient noise from the ignition coil primary winding from feeding into the vehicle's electrical system, which ultimately can be audible through the radio.
There is no dangling wire in your picture. The capacitor grounds by snapping into the clip connected to one of the regulator mounting bolts. It makes a single connection to the vehicle's electrical system (via the YELLOW wire).
Old Aug 19, 2013 | 06:15 PM
turbogus's Avatar
turbogus
Sorry for the lack of clarity of the photo, the very bottom of the pic is the wire's end that's only just outside of the margin. So if it makes a single connection to the vehicle's electrical system (via the YELLOW wire), where is the corrrect place to connect that yellow wire. (sorry that this sounds redundant).
Old Aug 19, 2013 | 08:09 PM
Franklin2's Avatar
Franklin2
That is a yellow/white wire and it connects to the "A" terminal of the regulator. I can barely see "A" in the top right of your picture in the black area on the regulator plug.
Old Aug 26, 2013 | 04:29 PM
turbogus's Avatar
turbogus
Cool! Thanks Franklin! So do I just splice into the existing wire that goes into the loom?
Old Aug 26, 2013 | 08:42 PM
Franklin2's Avatar
Franklin2
Yes,that will work.
Old Aug 27, 2013 | 08:15 AM
turbogus's Avatar
turbogus
Far Out! Thanks again Franklin~!
Junior8
Dec 31, 2015 04:42 PM
turbogus
Aug 20, 2013 08:30 AM
grinnergetter
Oct 12, 2011 09:53 PM
78_f800crewcab4x4
Apr 16, 2008 10:08 PM
