DSII swap problems. No Spark Electrical gremlins
The mechanical portion of the swap is complete. I went over the donor harness and it looks good. I plugged it in, hooked up the timing light spun over the engine and there is no spark. I checked for voltage at the coil. No voltage. I decided to unplug the dsii harness and verify the output of the three plugs on the cab side. This is where I get confused. The 4 plug connector has a red/white, white/red, brown/yellow, red/yellow. With the key on the red/white is pulsating 12v like a flasher. So is the white/red. The red/yellow is steady 12v. The brown/yellow is pulsating .2v. The 3 prong connector. Red/blue steady .2v, white/blue steady 12v, white/red steady .2v. The tach connector green is 0v and the black is 8v. My concern is with the pulsating voltages. I don't get it. Help please.
12v during cranking can come from the "I" terminal on the solenoid, but most of these trucks are wired with the bypass made into the ignition switch, Ford decided to get rid of the "I" terminal on the later models.
I do not believe the diagram shows that wire changing color, it should be red/green all the way to the ignition switch.
Why don't you verify you(we) are on the right trail, and run a wire from the battery + to the coil + temporarily, and see if it will try to start. You should not run it this way for a long time, but it will be enough to see if that is the real problem, or at least one of the problems.
on
on
Just run a jumper from the + battery to the + coil. If it starts than pull the jumper off. Let us know if it continues to run after pulling the jumper off. That is if she starts. Don't run it for a prolonged period of time with the jumper on as that is to much volts to the ignition in run. Don't complicate it with the resistance wire at this point.
