Range sensor or neutral safety problem? update
Old Aug 18, 2013 | 06:28 PM
427 fordman's Avatar
427 fordman
Today on the way home from the races, dumba$$ me ran the front fuel tank empty. Next time I travel I will have a full fuel jug with me. I thought about it friday, then thought, "I won't need it". Luckily I had enough additive in my bottle to fill up the pre pump filter, and most of the post pump filter. After some cranking I got it to fire up.
Now onto the actual problem. I cranked on it a bit before I filled the filters, and then after a bit I couldn't get it to crank. Just nothing when I turned the key. I put it in neutral and still had nothing. Then just messed with the shifter some and got it to crank. Then it kept working till I got it fired.
Thoughts? I just had a thought about the shifter bolts that come loose under the dash. I tightened mine up before, but that doesn't mean they aren't loose again. The more I think about it the shifter does seem a little sloppy again.
Think that could be it? I probably went and typed all of this and answered my own question.
Old Aug 18, 2013 | 06:45 PM
ReBilld's Avatar
ReBilld
At least it got answered LOL!!
Old Aug 18, 2013 | 06:50 PM
glovemeister's Avatar
glovemeister
Did yall loctite them bolts?
Old Aug 18, 2013 | 06:58 PM
427 fordman
Heck no Glove.
I'm guessing that's it Bill.
Old Aug 18, 2013 | 07:48 PM
stainlessstroker95's Avatar
stainlessstroker95
Some times you have to type it out befor it makes sense to you. Edit: how did you do at the races?
Old Aug 18, 2013 | 08:07 PM
fordpride's Avatar
fordpride
I'd think its the bolts. But if you do need a range sensor I have one in my box you can have if you want it. It a OEM about two years old
Old Aug 18, 2013 | 08:15 PM
427 fordman
I'm racing Dad's car as I'm in the process of selling my motor. Found a guy interested today too. I lost second round today. I cut a .002 light but the car fell off .06 from my dial in and I got beat by .001. An inch or so. Redlighted first round yesterday. I'm fighting a trans brake problem in the car. When I activate it it rolls ahead a little bit before locking, and doesn't roll ahead the same each time. Makes it hard to get my reaction time right. All my reactions were from -.010 (red light) to .011 on the good side all weekend, but I need to slow them down a little as that's flirting with disaster. It was really a pain as I had to wait a little longer to leave if it rolled ahead, and still sometimes redlighted. Gotta fix that. My car used to do that until I put a better trans brake in, might be what I have to do to this one.
Thanks Mike, mine is new with the rebuild this winter so it shouldn't be bad, but you never know.
Edit: Gabe, that is exactly what happened. I never even thought about that until I almost finished typing.
Old Aug 19, 2013 | 02:34 AM
stainlessstroker95
Sounds like a learning experince weekend then. Im sure you have to work out the bugs, just like when moding these trucks.
Old Aug 19, 2013 | 07:20 AM
oldbird1965's Avatar
oldbird1965
It would be nice to somehow be able to prime the filters instead of dropping them down and filling them.
Old Aug 19, 2013 | 02:23 PM
fordpride's Avatar
fordpride
You could put filter heads with pump primers
Old Aug 19, 2013 | 02:52 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Electric fuel... Jump power to the pump and let the pump prime the system before cranking it... I always do this when I break my fuel system apart, except when I change my filters. I never fill the filters when I change them out.
Old Aug 19, 2013 | 04:28 PM
ReBilld's Avatar
ReBilld
X2 ^^^^^^^^^^
Old Aug 19, 2013 | 06:18 PM
427 fordman
I tried letting the key just be on for a while to hopefully let the pump fill them. I let it run, turned it off, let it run, off, etc. a few times trying but to no good ending. They had some fuel in them when removed, but not a lot. Although my quart of additive filled one and almost filled the other and the quart was about 1/3 gone.
I still had air in it when I got home, 35 miles later. It cranked a while before firing after I unhooked.
Old Aug 19, 2013 | 06:54 PM
ReBilld's Avatar
ReBilld
Does your pump run when you turn the key on? I wired mine with an oil psi switch like Travis' so the pump doesn't run until you start cranking, then oil psi switches it over to key on power.
Old Aug 19, 2013 | 06:57 PM
427 fordman
With the strictly diesel harness I have it runs for 30 or 60 seconds(can't remember) with the key on before it will shut off if you don't start it. That's why I turned it on and off a few times. I couldn't get it to show over 10psi until I filled the filters. Maybe it would have worked if I would have done it a few more times, I don't know.
