Cleaning Injector Cup question
Old Aug 17, 2013 | 08:04 PM
Groundpounder0331's Avatar
Groundpounder0331
I have carbon build up in my injector cups from improperly seated injectors. Can I use brake parts cleaner to help dissolve the carbon, or some other cleaner. Right now a wood dowel and rags is taking an extremely long time. Thanks!
Old Aug 17, 2013 | 09:58 PM
stainlessstroker95's Avatar
stainlessstroker95
I have heard that gun oil can help disolve it but not sure. You may have to end up putting new cups in.
Old Aug 17, 2013 | 10:18 PM
mjunk1's Avatar
mjunk1
I don't know, but wonder if you soaked the rag in some seafoam if that would work? That stuff is really good on carbon.
Old Aug 18, 2013 | 10:04 AM
Groundpounder0331
I'll try the seafoam rag idea. Last night I stuck a rag soaked in wd-40 and that helped. I used a nylon toothbrush dipped in wd-40 as well and that was working. I just want to make sure whatever I use won't cause an engine problem if it leaks into the combustion chamber. I pressure tested the cooling system and there were no leaks. I may end up replacing the cups, but I really want to avoid that. The tool required is about $300 or more.
Old Aug 18, 2013 | 10:08 AM
Groundpounder0331
I having computer issues, disregard this post. I can't figure out how to delete it.
Old Aug 18, 2013 | 11:21 AM
fordpride's Avatar
fordpride
I used a 12 gauge barrel cotton swab on a drill soaked in carb cleaner
Old Aug 19, 2013 | 10:38 AM
Groundpounder0331
I pressurized my coolant system, and then assembled my 12 ga cotton swab. When I returned, guess what... #7 cylinder cup is leaking coolant at 16 psi. Soooooo, now it's time to replace them. Might as well get them all done. What sucks is I'll need to tow the truck to a local shop to change them out. I just don't have the tools nor confidence to do it myselft.
Old Aug 19, 2013 | 11:34 AM
mjunk1's Avatar
mjunk1
I don't know if others would be interested, but I'd chip in to buy the tool together with some guys and then just ship it around to whoever needs it. Seems like it could be pretty straightforward if we got 10 guys together. It's such a seldom used thing for someone like me, but I really think it is worth replacing my cups when I do my injectors given I'll have 250k on the engine by then.
Old Aug 19, 2013 | 01:07 PM
Groundpounder0331
Check this out. Cups for $98, Retaining compount for $29, rent the install/removal tool for $50.00. Total cost is $178. If I have a local shop do the work, it will cost $650 after towing two ways, labor, and parts. Looks like a no brainer for me. Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts?
Old Aug 19, 2013 | 01:51 PM
Groundpounder0331
Hmmm. The above link isn't working. Try to locate OEM/Factory Parts link on the Riff Raff website, and look for this part number: F4TZ9F538A :Motorcraft 7.3L Injector Cup Repair Kit.
Old Aug 19, 2013 | 03:55 PM
mjunk1's Avatar
mjunk1
That makes it seem like a no brainer. i suppose you could tap them too if you are trashing the old ones. Probably still a pain to get out and then you might have pices of metal down in the cylinder. Thanks for the info.
Old Aug 19, 2013 | 07:50 PM
fordman67's Avatar
fordman67
The rifffraff tool works great according to gabe.you can do it!
Old Aug 20, 2013 | 11:43 AM
Groundpounder0331
I'll have the tool NLT Thursday. Should have it done on Friday and I'll post the results.
Old Aug 20, 2013 | 01:18 PM
fordpride's Avatar
fordpride
When you think the bores for the cups are clean enough clean them again
Old Aug 21, 2013 | 12:20 AM
stainlessstroker95
Yes it works great! Make sure to put oil on the instalation tool orings.
