what do i have
Old Aug 15, 2013 | 10:12 PM
winterkill's Avatar
winterkill
what do i have
i bought a 79 f150 today. wanted one for a long time. i have some basic information about the truck but id like to hear what u guys can pick out from a picture. as far as i know it has a 3/4 ton drivetrain, a 4 speed manual transmission, a 460ci engine, and so on. i want to first redo the brakes all the way around as they are pretty soft. i tried bleeding today but snapped off 3 of the 4 bleeder deals... and input would be helpfull.
Old Aug 16, 2013 | 12:11 AM
460 FORD MAN's Avatar
460 FORD MAN
The pic isn't working for me.
What exactly are you asking?
Old Aug 16, 2013 | 12:24 AM
fordcrzymike's Avatar
fordcrzymike
Picture isn't working. Try using an image hosting website like photobucket and post the IMG code here. If you post the door tag on here we could de-code it for you, but it sounds like the truck has been somewhat modified already.
Old Aug 16, 2013 | 05:49 AM
gnwalker's Avatar
gnwalker
Pic is working, looks like 3/4 ton drivetrain to me
Old Aug 16, 2013 | 02:01 PM
keiths78f150's Avatar
keiths78f150
Again, pic isn't working for me neither. Weird.
Old Aug 16, 2013 | 02:08 PM
brian1080's Avatar
brian1080
That's either a Supercab 79 f150 with a 3/4 ton axle swap or it's a Supercab 79 F250. It could also be a 79 F350, can't tell from pic.
Get some pix of the axles and door stickers and list the vin, specifically like the first 4 numbers.
Old Aug 16, 2013 | 04:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by winterkill
1979 F150 3/4 ton drivetrain, 460, 4 speed manual.
It's a "Frankenstein monster" with parts swapped from lawd only knows what. For one thing, the 460 was not available with a M/T or 4WD until 1983.
Warranty Plate located on the left door face below the latch. VIN stamped on it is known as the Warranty Number .. it's not used for title or registration purposes, as it's too EZ to change.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
The only VIN that matters is hidden on the frame, it's what DMV/Law Enforcement go by. They compare the hidden frame VIN to the VIN on the title/registration to verify it matches.
Safety Standard Certification Label glued to the left (drivers) side B piller, below the striker plate. Has the VIN, production date and front/rear GVW (some have the tire size) printed on it.
The problem: Label has two layers, outer is clear. When these labels got wet, the outer layer peeled off, taking some/all of the inner layer along with it.
Old Aug 16, 2013 | 04:45 PM
arctic y block's Avatar
arctic y block
Pic not working for me. Goes round and round and...........
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Aug 16, 2013 | 05:38 PM
brian1080's Avatar
brian1080
Simpler version: right click picture, copy location. click image icon (little mountain with moon) and paste location.
Old Aug 16, 2013 | 06:52 PM
arctic y block
I can see that. Thanks. Nice truck
Old Aug 17, 2013 | 10:39 AM
winterkill's Avatar
winterkill
pictures
ok im learning this photo upload thing
Old Aug 17, 2013 | 10:42 AM
winterkill's Avatar
winterkill
second try
winterkill's Avatar
winterkill
third
Old Aug 17, 2013 | 10:43 AM
winterkill's Avatar
winterkill
4th
Old Aug 17, 2013 | 11:15 AM
rogue40's Avatar
rogue40
You have a newer cab (or door) on an older Highboy.
Or the special order 79 f150 Highboy 8 lug with extra slim Dana 60. Might as well have a 390 too.
