what do i have
Old Aug 17, 2013 | 12:04 PM
fordrealdrive's Avatar
fordrealdrive
You have what some refer to as a Frankenstein truck. I see a '78-79 supercab 4x4 chassis that has had the married trans/transfer case replaced with a divorced setup. The correct front axle which would be a high pinion d44 or high pinion d60 has been replaced with a low pinion d44 from a highboy .
Old Aug 17, 2013 | 12:05 PM
brian1080's Avatar
brian1080
Yeah, a 79 shouldn't have a divorced t case and sticker is not for an F250. Does your title match your sticker, cuz it's probably not right if it does. Check frame vin.
Old Aug 17, 2013 | 12:48 PM
march's Avatar
march
Agree with the others. The cab is from a 79 supercab F150 4X4. Orignal engine was a 351. None of the running gear matches that. Need to find that frame vin to see what it's sitting on.
Old Aug 17, 2013 | 05:36 PM
winterkill's Avatar
winterkill
Where can I find the frame vin?
Old Aug 17, 2013 | 05:52 PM
march's Avatar
march
Borrowed this image from MontanaHighboy
Mine is just forward of the firewall behind the axle. (78 supercab 4x4)
Old Aug 18, 2013 | 12:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rogue40
You have a newer cab (or door) on an older Highboy.
Or the special order 79 f150 Highboy 8 lug with extra slim Dana 60. Might as well have a 390 too.
Impossible. FoMoCo didn't offer F100's or F150's with F250 specific brake/driveline parts, 360/390 cancelled at the end of the 1976 model run.
VIN as printed on Safety Standard Certification Label pictured in post #12:
X14HKEH1496
X14 = F150 4WD Super Cab Pickup.
H = 351M
K = Kansas City MO Assembly Plant.
EH1496 = 1979.
Old Aug 18, 2013 | 04:04 PM
rogue40's Avatar
rogue40
Yes Bill, I know. Please forgive my vane attempt at humor.
Old Aug 18, 2013 | 10:25 PM
keiths78f150's Avatar
keiths78f150
Hahaha Ol Bill is ALL business.
Old Aug 18, 2013 | 11:17 PM
spikinfool05's Avatar
spikinfool05
is that t-case mount even stock?
Old Aug 18, 2013 | 11:41 PM
fordrealdrive
The mounts are all stock highboy parts ,"mounted" to a custom tube x-member. Really a trick setup in my opinion.
Old Aug 19, 2013 | 01:13 PM
wooddyusa's Avatar
wooddyusa
Hey winter kill...I have a bit of a Frankenstein truck myself. In my opinion the previous owners who put it together did a pretty good job. Hopefully yours is put together well too. Nice truck man. Have fun with it!
I never was able to locate a VIN on my frame. I hope to find it when I pull the front clip and get a closer look. I thought I might find one when I had the floor pans out. Didn't happen.
Old Aug 19, 2013 | 09:57 PM
winterkill's Avatar
winterkill
thanks
thanks. i think this one was done right also.... i have limited knowledge of the truck but iv found a pretty good group of guys here! i should include a pic of the engine compartment.whoever did the work seemed to know how things worked. my truck has a new super thick radiator retrofitted into it. also a new fuel tank. the bed is fairly new as the mounting bolts are still shiny...... it will be a fun truck to mess with. no plans on rodding it really, i will use to haul firewood and to access some distant hunting ground!!!
Sailor Roy
Montana Chapter
265
Sep 30, 2018 08:28 PM
andres0517
Feb 14, 2013 10:53 PM
TyWebb
6.7L Power Stroke Diesel
29
Mar 19, 2011 10:32 PM
JesseRohr
6.4L Power Stroke Diesel
16
Jul 15, 2008 02:10 PM
DELBERT
Modular V10 (6.8l)
Sep 29, 2005 04:21 PM
