1978 - 1996 Big Bronco
Fuel pumps running
Old Jun 14, 2003 | 04:07 PM
Big Red Bronco's Avatar
Big Red Bronco
Fuel pumps running
Hi All, this is actually a spinoff of the fuel pump question.
From the answers I've seen there may be more to the fuel pumps not shutting off on the 87 up Bronco's.
Mine, in tank and frame rail mount, have been running constantly at times. Last week the frame rail mounted one burnt out. I've replace the relay, which was bad, however, that was not the solution.
I had assumed that the crummy trailer wiring harness was at fault, by being shorted and thereby shorting the fuel pump harness. But, I havn't found any short.
I know the "computer" is supposed to turn off pumps after so many seconds. But there must be some problem that makes it "think" the engine is running and therefore keeps the pumps running.
ANY ideas?
Bruce (Big Red Bronco)
Old Jun 15, 2003 | 12:13 AM
steve83's Avatar
steve83
Fuel pumps running
The EEC uses the PIP signal (sensor inside the distributor) to determine if the engine is running and the pumps should stay on. If the relay stays on (keeping the pumps on), find the short to ground in the trigger wire from the relay to the EEC.
belchfire
Jul 8, 2016 06:26 PM
secreto622
May 24, 2016 06:01 PM
annaleigh
Oct 25, 2015 10:43 PM
master link
Aug 24, 2006 11:19 AM
Scruffydog
Bronco II
13
Apr 26, 2004 12:32 AM
