fuel pump boost
Old Jul 8, 2016 | 06:26 PM
belchfire's Avatar
belchfire
fuel pump boost
Got a '90 F-250 W/ a 351w. It's always cut out & had no power since I've had it. It was owned by a real billy-bob and run into the ground. I re-built the engine & it still cuts out. Previous suggestions pointed to the FPR and the coil and filter. All were changed with no success. I installed a gauge on the fuel rail and it's running30 psi @ idle and 35 psi when the vacuum line is off. I hot wired the return line to a valve and shut it off. Front pump stalled @ 35psi. Rear @ 50. Obviously, the front pump is gone but the rear isn't all that healthy either. New pumps run $100-$130 each. plus there's the horror of pulling the tanks. I have a frame mounted pump from an '89. What if I installed it between the filter & the fuel rail? If that's too much, then maybe cutting the tank pump wires?
Just a work truck not my masterpiece (that's carbureted thank you very much).
poppatello
29
Mar 9, 2019 07:53 PM
Dr. Johnson
Oct 16, 2016 06:49 PM
thrilher
1978 - 1996 Big Bronco
Apr 13, 2009 12:09 PM
cookie88
26
Oct 11, 2004 08:34 PM
