1958 steering box
Old Aug 14, 2013 | 09:07 PM
mont974x4's Avatar
mont974x4
1958 steering box
I'm picking up a '58 F-100 4x4 this weekend. I am seriously stoked.
The seller told me the steering wheel is sloppy but the steering is tight. Of course it is. So, do I need any special tools to rebuild the steering box? Or should I just order a remanufactured one?
I suppose I could get lucky and the steering needs adjustment....but even then it's only a stop gap.
No worries...pics will be posted ASAP.
Old Sep 20, 2013 | 09:39 PM
yaak263's Avatar
yaak263
Car steering wholesale web site has rebuilt steering boxes. spendy but the rebuilg kit i found was over 500 dollars
Old Sep 21, 2013 | 09:32 AM
dcagnolatti's Avatar
dcagnolatti
You don't have the tuck yet? Could be anything. Sellers often misdiagnose problems. That was the case with my '59. The steering was very loose and she wiggled going down the road.
My problem was a bent tie rod and worn out wheel bearings. Steering was just fine.
Old Sep 21, 2013 | 10:49 AM
mont974x4's Avatar
mont974x4
I have the truck. I picked it up that weekend. The steering wheel goes from 1 O'clock to about 7:30 before it moves the tires.
Old Sep 23, 2013 | 06:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Typical Ford truck loosy-goosy manual steering, having a minimum of 4" of play is rather common.
redheadsteeringgears.com in Seattle WA will rebuild your gearbox.
The thing is, since the steering shaft (3524) goes directly into the gearbox, you have to pull the steering column and the gearbox as a unit.
But first, you have to disconnect the shift linkage (unless a 4 speed), remove the steering wheel and disconnect the draglink from the Pitman Arm.
Unless you get lucky and can wiggle the steering wheel off, you'll need a steering wheel puller. You'll also need a pickle fork aka Pitman Arm (3590) puller.
Old Nov 26, 2018 | 11:33 AM
crneville's Avatar
crneville
Resurrecting an oldie
Hi all, not sure if it’s wise to reply to a five year old thread or not, but here goes lol. Lots of great info here, just wish that “Earls World” was still available!! Anyhow, any special tools needed to rebuild the manual gear box on 57-60 ie: presses etc? Looks pretty straight forward and I just might tackle it if I can’t find an old Toyota manual box from a junkyard. Thanks!!
Old Nov 26, 2018 | 12:52 PM
NumberDummy
Factory installed 4WD was introduced in 1959 F100/250's. If your truck is a 1958, it's an aftermarket 4WD conversion, possibly by Marmon-Herrington.
1959/60 F100/250 4WD's use a different steering gear box than 2WD's.
Rachel Moody
15
Jan 16, 2017 11:51 AM
Fordsdad
Nov 21, 2013 06:52 AM
351Cleveland C4
15
Jul 15, 2013 01:06 PM
midsouth
Apr 6, 2012 07:01 PM
kwemj 67
Sep 2, 2010 10:26 PM
