Class A Motor Home with "mild" Performance 7.3
#76
#77
Got the Belts on and filled the Hydraulic oil and fired the beast off....The engine is a bit harder to start than it was when it was warmer out....But that's to be expected... The power steering works, and the hydraulic fan works, as dose the trans cooler fans. now that I have the Air system up to pressure I can set up the Air throttle. Getting closer to test drive time. I should have all the air cleaner parts here by Friday so I should be driving it by Sunday.
#79
#80
#81
#82
I got my throttle modified and installed. I was able to put the MH into gear and ease into the throttle against the Torque converter and get 10psi boost pretty easy. It was dark so I didn't get any pics. I got a late start today my back is all tight from a goofball maneuver I did yesterday afternoon. I have a few more things to finish up with the throttle servo mount and the trans cooler fan relay. I need to pull the intercooler back out to finish up a few things like the Air cleaner, turbo blanket and some P clamps on the air compressor lines. If it's not raining to hard I should get most of that done and can go for a test drive.
#83
#84
Well I thought about a dt466...and almost went with one...I found one with a 6 speed Allison for 2500.00 but I just couldn't swing that much money...To change to a 6 cylinder like a 6bt I would need to change the rear gear ratio or trans and shifter system, So I researched 9.0L International, Cat 3208, Both of them are harder to find any performance info or parts than the IDI so I just built a mild performance 7.3 that will out perform the feeble 8.2 Detroit and be cheep to keep running. I didn't need to change any trans or gear ratios, I just needed to modify the Accessories to fit and build a turbo system to work with the Engine. No problem..... It only took me 7 months once I got started building the Engine.....Not to forget the 3 years of looking for parts and stuff and the year or so of thinking about it....LOL...
#85
#86
Well the PO said he got 12 with the 8.2 going over Stevens pass here in WA. So I hope to get 12mpg out of this 7.3 Its got smaller displacement and less rotating mass compared to the 8.2 . If I get less than that I will be a little disappointed. If I get better than 12mpg I will be happy. Most of the time I will be towing two horse's when we get to AZ. Today I got another late start and it was raining all day. didn't get as much done as I had planed. I also ran into a problem with the Hydraulic fan bypass valve. I was rewiring it to a relay with fused power and the wires at the solenoid coil broke off all corroded flush with the coil. So now I am going to try a coil off a hydraulic slide out pump from a MH and see if it has the right size center hole to fit my bypass valve. I have a trip planed on Thanksgiving weekend so I got to find something to work or It will be running with full time Hydraulic fan on that trip.
