lifted 4.9?
Old Sep 14, 2013 | 01:03 AM
SumB's Avatar
SumB
Towing might just make me more fond of the engine. I didn't buy mine to tow tho. I wasn't looking for anything fast either. I was just looking for something dependable for day to day driving with occasional light off road use (hunting/winter driving).
Old Sep 14, 2013 | 01:11 AM
SumB's Avatar
SumB
Quincy that sounds like a gem, you should be proud! I really like the more simple 90s pickups with the more classic looks. They are te best of both worlds in my opinion.
Old Nov 29, 2013 | 11:12 PM
codejunkie's Avatar
codejunkie
Big tires and lift kits look cool, without a doubt. "But", taken to extremes these after=market changes result in problems I moved away from some time ago.
Heavier wheels and tires result in reduced braking efficiency because of the greater weight spinning through the rotors/drums. Radical angles of the u-joints from lifted components causes greater stress and wear on the joints. Excessive lift changes the center of gravity which can be a problem when traversing defiles and slopes. Huge tires can reduce the pounds/square inch, not allowing the tires to cut through heavy slush/snow to get a grip on the road. But we still do it, don't we?
Old Nov 30, 2013 | 06:58 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The torque curve is a key factor. Stock 4.9l reaches peak torque at "roughly" 2000rpm. The closer you are to that in any given gear the better. In high gear for an automatic, 3 or 4 speed, the final ratio is 1:1. Any change in tire size affects the rpm for a given speed. Here is a calculator to play with different gear ratio's: Gear Ratio Calculator
Larger the tires, lower the gears needed to maintain the balance. My "little" six was built entirely for the torque curve, not horsepower. While it does not reach peak torque till 2850rpm, (55mph with 30" tires and 4:11 gears), it varies very little from 1200rpm to 4000rpm. All the other issues to consider when changing tire size, suspension have been mentioned.
hawkman76
Mar 14, 2019 07:49 AM
bluemtn95ford
34
Oct 10, 2012 12:40 AM
Kudofo
33
Nov 5, 2011 06:57 PM
deemac
48
Oct 12, 2007 12:12 AM
ImNew
Mar 16, 2003 08:43 PM
