trans code
Old Aug 13, 2013 | 03:23 PM
robbiebrown25's Avatar
robbiebrown25
trans code
I'm looking to put a 302 in my 1990 f150 it's is four wheel drive 4 speed and I need to find out what trans would be good to replace in it. right now I have the 300 6 in it does have 3.55 gears in back
Old Aug 13, 2013 | 03:37 PM
Encho's Avatar
Encho
The Southernmost Mod
You don't need to replace the transmission to replace the engine, is it an automatic with O/D? but one bit of advice, don't use the 302, go with a 351 or even better: get another 300 I6, it will require no modifications and it outperforms the 302 in most of the usual truck tasks.
Old Aug 13, 2013 | 07:57 PM
robbiebrown25
Its a 4 speed trans will it match up to a 351 and its 4 wheel drive
Old Aug 13, 2013 | 08:45 PM
Encho's Avatar
Encho
Manual or auto?
Old Aug 13, 2013 | 09:56 PM
robbiebrown25
Manua 4 speed. 3.55 gears in rear have to start off in second gear all the time 4 wheel drive if it matters
Old Aug 13, 2013 | 10:47 PM
Encho's Avatar
Encho
It should match the 4 speed since the 300 and both V8s share the same bellhousing pattern. The flywheel is different I think, you might want to look into that.
Old Aug 13, 2013 | 11:03 PM
robbiebrown25
Thanks dont really know much about ford learning a lot thanks for all the help
Old Aug 13, 2013 | 11:31 PM
Encho's Avatar
Encho
But believe me, the I6 is as good as it gets torque-wise and reliability-wise (more than 300,000mi isn't a rare occurrence for these), it's a good choice and will save you a LOT of research, troubles, and fabrication.
92 f-150
Aug 10, 2008 09:25 AM
fordbeast_80
Feb 27, 2006 12:04 AM
RockyBhm
Apr 14, 2000 10:03 AM
david73796
Mar 1, 2000 07:56 PM
