Spare and jack
Old Aug 13, 2013 | 08:45 AM
ccllud's Avatar
ccllud
Spare and jack
I have an 02 4x4 v10 Ex that has modded V and modded B codes. I just upgraded from 265/75/16 to 285/75/16 Michelin A/T2's.
My current spare is 265/75/16, will that be fine or do I need to get a 285 sized tire? (Im asking because on my acura, the donut spare is way smaller)
Will the stock jack or a 6ton harbor frieght jack do fine? or do I need a highlift jack?
Old Aug 13, 2013 | 12:02 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If you ever have to drive very far with that spare on, it can cause damage to your differential in the rear. There is a 1" size difference between a 265/75 and 285/75, which is pretty significant for a differential to absorb. I think your stock jack should be fine....or a big bottle jack.
Old Aug 13, 2013 | 12:14 PM
ccllud's Avatar
ccllud
How did those car companies get away with such smaller donut tires? My acura donut was significantly smaller
Old Aug 13, 2013 | 03:45 PM
mgraveman's Avatar
mgraveman
On the rear axle of a front wheel drive or front axle of a rear wheel drive the tire size is more or less insignificant. That's not technically true, but it works for the donut tires. Start adding heavier drivelines with limited slip and stuff like that and it makes it harder for the driveline to compensate for the different axle speeds.
Old Aug 13, 2013 | 05:12 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Those little tires you are talking about clearly state they are for emergency use only. They have very low speed limitations on them, and most owners manuals tell you to only drive to the tire shop with it on there. Most people ignore or don't even bother to read those warnings, though. I have answered calls to people stranded on the side of the road too many times over the last two decades who have those little donut tires on their cars and they failed. Almost all of those people had been driving around for DAYS on the donut and at highway speeds to boot. If you put one of them on the front of a front wheel drive car and drive it for days, you are doing damage to your transmission and possibly the CV joints as they try to match each other, but can't. You have two tires that are traveling different distances with each revolution which = not good.
Old Aug 13, 2013 | 05:19 PM
Stewart_H's Avatar
Stewart_H
Smaller, lighter vehicle.
That's why you never saw a donut as a spare on a truck or SUV.
A lot of cars don't even come with spare tires anymore, donut or otherwise, to save money.
Stewart
Old Aug 14, 2013 | 07:15 AM
ccllud's Avatar
ccllud
sounds like ill be doing a little craigslist shopping today for a spare then. Thanks yall for the responses
1stexcursion17
Sep 28, 2017 08:34 PM
Pool Runner
2009 - 2014 F150
Aug 11, 2013 09:48 PM
ccllud
Mar 10, 2013 06:55 PM
VQT
Dec 2, 2012 05:15 PM
Blue Blooded
2004 - 2008 F150
Dec 19, 2004 06:29 PM
