Burning up generators
Old Aug 12, 2013 | 07:06 PM
altruego's Avatar
altruego
Not sure what is going on here but my '05 F-350 6.0L is eating up generators like a kid in a candy store. Last one didn't even last a month. Previous one lasted 6 months.
I'm suspecting something in the charging system isn't right. Anyone have any experience with this type of problem?
Old Aug 12, 2013 | 07:38 PM
BLADE35's Avatar
BLADE35
Yes I have See my SIG
are your Batterys OKcables???
Old Aug 12, 2013 | 07:40 PM
BLADE35's Avatar
BLADE35
https://www.dcpowerinc.com/
Old Aug 12, 2013 | 08:19 PM
raptor131's Avatar
raptor131
Without knowing anything else I would recommend checking all your cables and connections, as well as the batteries. Loose connections will kill them quickly. I have witness them literally catch fire.
Old Aug 12, 2013 | 08:29 PM
99ExpyProblems's Avatar
99ExpyProblems
What alternator are you putting on your truck? Advance Auto? Auto Zone? O'Reilly? OEM Motorcraft? Remanufactured or New?
1. What is your battery Voltage with the Engine Off?
2. What is your battery Voltage with the Engine Running?
3. Is your Charging System Warning Indicator On?
Old Aug 12, 2013 | 08:47 PM
altruego's Avatar
altruego
The first one I put in was an AutoZone, second one was a Remy brand.
Battery voltage is 15.5 with the engine off. I know that is too high.
With engine running voltage is 11.7 and stays around 12 until the engine is at temp and then goes to 13.9
The charging system light is on and we have the generator 1 code.
Old Aug 12, 2013 | 09:21 PM
99ExpyProblems
So you have the dual alternators option right? And you have any of these DTC's listed below?
P0620 Dual generator upper fault detected
P0623 Dual generator battery lamp circuit fault detected
P1148 Dual generator lower fault detected
P1149 Dual generator lower circuit fault detected
P1397 System voltage out of self-test range
Old Aug 12, 2013 | 10:15 PM
dangerelectric's Avatar
dangerelectric
Did you do any modifications? Like running a new power and ground off the alternator to the secondary battery? This helps level out the spikes and saves the systems a bit. More talk of doing this on ficmrepair.com
Old Aug 12, 2013 | 10:33 PM
BLADE35's Avatar
BLADE35
that's wild is the Battery BOILING LOL
A Battery is Considered Fulley Charged at 12.68volts
First Iv seen a Float charge High like this
Make shure Both ground cables have good conections off the battery follow to frame and engine Mounts
What DTC
Old Aug 12, 2013 | 10:35 PM
BLADE35's Avatar
BLADE35
I think the Guys have found a few other Good Solutions for High Output Alt
Idealy the More Amps you get the Better the truck does But also you want quality so you don't have to worrey about things Like FICMs and Short Life Alternator unit that stresses all the Trucks electronics Fast each time they Die
Old Aug 13, 2013 | 11:01 AM
99ExpyProblems
If you can answer the questions I posted, I'm reading directly from the shop manual. If you want to find the solution, there are steps to follow. If you don't have dual alternators then the questions I have asked don't pertain to you.
Old Aug 13, 2013 | 11:18 AM
altruego's Avatar
altruego
I do have the dual alternators.
The codes are:
Old Aug 13, 2013 | 12:05 PM
99ExpyProblems
First thing you want to do is disconnect the Batteries and have them tested at an Auto Parts store. Have them tested 1 at a time on their machine and have them replaced with known good batteries if they fail (likely failed batteries if you have 15.5 volts with engine off) or all of these tests below may be worthless.
Functionality
With the key in the ON position (dual generator system), voltage is supplied by the powertrain control module (PCM)-controlled I circuit 1183 (WH/YE) / 904 (LG/RD) to the upper generator and through the I circuit 1185 (YE) to the lower generator. If the glow plug system is not cycling, the PCM maintains power to the lower generator. If the glow plug system is cycling, the PCM supplies power to the lower generator momentarily to verify there is a volt drop, then shuts off the power on the lower generator I circuit 1185 (YE). Once the glow plug system stops cycling, the PCM supplies power on the lower generator I circuit 1185 (YE), which turns the regulator on allowing current to flow from the battery sense A circuit to the generator field coil, at which time it begins to function normally. The PCM maintains power on the upper generator I circuit 1183 (WH/YE) / 904 (LG/RD), which turns on the regulator, allowing current to flow from the battery sense A circuit to the generator field coil.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator internally. This voltage feedback signal (typically one-half of the battery voltage) is used by the PCM to turn off the charging system warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage varies with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for more efficient battery recharge in the winter and reduces the chance of overcharging in the summer.
Positive Battery Output (B+) Circuit 1119 (RD) (Upper) / Circuit 36 (YE/WH) (Lower)
The generator output is supplied through the positive battery output (B+) terminal on the rear of the generator to the battery and the electrical system.
I Circuit — Dual Generator
The I (ignition) circuit is used to turn on the voltage regulator(s). This circuit is powered up when the key is in the ON position. When the PCM detects key ON, the PCM provides power to the upper generator I circuit 1183 (WH/YE) / 904 (LG/RD) and also to the lower generator I circuit 1185 (YE). The power to the lower generator is only momentary unless the glow plug system is not cycling. Once the glow plugs stop cycling, the PCM provides constant power on the lower generator I circuit 1185 (YE).
A Circuit 35 (OG/LB)
The A circuit or battery sense circuit is used to sense battery voltage. This voltage is used by the regulator to determine generator output.
Inspection and Verification
WARNING: Batteries contain sulfuric acid. Avoid contact with skin, eyes, or clothing. Also, shield your eyes when working near batteries to protect against possible splashing of the acid solution. In case of acid contact with skin or eyes, flush immediately with water for a minimum of 15 minutes and get prompt medical attention. If acid is swallowed, call a physician immediately. Failure to follow these instructions may result in personal injury.
WARNING: Batteries normally produce explosive gases. Therefore, do not allow flames, sparks or lighted substances to come near the battery. When charging or working near a battery, always shield your face and protect your eyes. Always provide ventilation. Failure to follow these instructions may result in personal injury.
WARNING: When lifting a battery, excessive pressure on the end walls could cause acid to spew through the vent caps, resulting in personal injury, damage to the vehicle or battery. Lift with a battery carrier or with your hands on opposite corners. Failure to follow these instructions may result in personal injury.
NOTICE:
Do not make jumper connections except as directed. Incorrect connections may damage the voltage regulator test terminals, fuses, or fusible links.
NOTICE:
Do not allow any metal object to come in contact with the generator housing and internal diode cooling fins. A short circuit may result and burn out the diodes.
NOTE:
While carrying out any pinpoint test, disregard the diagnostic trouble codes (DTCs) set while following the specific pinpoint test. After the completion of any test, be sure to clear all DTCs in the PCM.
NOTE: All voltage measurements are referenced to the negative (-) battery post unless otherwise specified.
NOTE: The dual generator I circuit/bulb circuit 4-way connector MUST be connected before disconnecting or connecting the battery. The PCM relearns its parameters every time it is disconnected and connected to power. Failure to follow this procedure causes the PCM to misinterpret the charging system as a single generator system, causing loss of DTC capability and control.
Once you've reached this step, let me know I'll upload more pinpoint tests.
Old Aug 13, 2013 | 01:07 PM
altruego's Avatar
altruego
Just had the batteries tested and they are good. I'm thinking my crappy HF voltmeter is lying to me.
Old Aug 13, 2013 | 01:23 PM
99ExpyProblems
That's not the one that comes free in the flyers is it? Get rid of that thing! lol
